429 rebuild timing question
hey guys, i was helping one of my friends yeasterday on a project of his. He has a 429 out of a 60's something tbird he rebuilt prettywell stock except rv cam, msd hei ignition, edelbrock intake and carb. we got it to run and sounds pretty good but i cant seem to drop the timing much below 25 btc or it starts running bad and diesels when it shuts down. i wasnt there when he built the motor but he said he aligned the dots on the timing gears. anything that i should be looking for.
thanks for the help.
i think everything is fiqured out. I still need to get some of the build reciepts and look at the comp ratio. timed the engine a 34 deg at 3000rpm so the msd wasnt multiple sparking and found out that the factor comp ratio was 11-1 so regular pump gas probally isnt going to run that well anyway.. i know that it has flat top pistons in it now just have to fiqure out the part numbers.
nothercrash
09-23-2010 10:43 PM
fudgythewhale
09-27-2004 07:40 AM
79_custom
06-12-2003 07:09 PM
Darin
02-29-2000 05:00 PM
