Where to service?
Where to service?
Hi, I've searched around and haven't found what I was looking for. I have an 07 PSD and need some cooling system work done. My two choices are Hillsboro-long drive, bought it there, good luck so far- or Rountree-closer to home, not sure if they specialize in the PSD...Any opinions?
Ok,
I am a bit confused. I see you say you are in SW NH but Rountree Ford according to Google is near Lincoln NH.
If you are in the Lincoln area you are near UncleJunk and Ron'sPowerstroke. Send a PM off to Ron or unclejunk. They are both NH chapter members and are probably willing to help point you in the correct dirrection.
If you are really in SW NH than send a PM to Big Ken. Sure he's in Ma but I think he might be able to point you in the correct dirrection as well.
Rountree Ford is now in Keene-pretty sure they're also in Brattleboro, VT too. I ended up bringing my truck there since it's on my way home from work. My truck is under the knife for a radiator and head gaskets. Thank goodness it's still covered under warranty.
Thanks for the info about contacts.
Where in Keene?
I know David (I think Ford ws in Keene but it's now a Kia dealer or somthing like that.
I also just remembered that in the chapter stickies in a chapter members map.
It's a google thing and you should be able to put in your location on the map. You do need a gmail account (at least I think you do becuase you need to log into google to edit the map). If not I can add you in. I also put a bunch of NH Dealerships on the map as well.
If you would like to join the NH chapter feel free to do so.
When we actually start doing things again I use the NH Chapter member list to send off mass PM's.
90pioneer
Oregon Chapter
04-26-2011 12:21 AM
