Adding oil to the fuel
This weekend I talked to an expert on diseals. Work on a lot of semis. He said with the new low sulfur fuels the injectors will wear out. In his 2005 Chevy truck he adds a qt of automatic transmission fluid or Marvel Mystery oil to each 40 gallon fill up. He says that this quiets down the injectors and increse their life. He says he has 80k on the original injectors. He does say that the truck will smoke a bit. I have a 2010 F250 6.4 and I use Diseal Kleen in the silver container. Does anyone add oil to the fuel and does this help the injectors? Does the Diseal Kleen help? How long do injectors last on this model? I live in Southern California and I don't really want my truck to smoke. Thanks
I have run Stanadyne (or Diesel Kleen if I am out of Stanadyne) in every tank of my personal truck since new.
My brother has an '04 with 140k on the clock, Stanadyne or Diesel Kleen in every tank, with all original injectors.
Just keep using the Diesel Kleen, that is a far more beneficial product than just dumping oil in the fuel.
Most of the people who have added oil were to models that were built prior to the ultra low sulfur engines. Your engine is designed to run on the low sulfur so I don't know if you would see any noticeable results. I have a 2004 and have put 2 cycle oil in my fuel as it is designed to burn when mixed with fuel. It di quiet my engine some but I saw no other noticeable difference.
Here is an interesting study from 2007, showing the effects of lubricity on ULSD of various additives, including motor oil, Marvels Mystery Oil, Diesel Kleen and 2 stroke oil.
http://rivrdog.typepad.com/files/cop...-version-3.pdf
Notice some additives, including Marvel Mystery Oil, actually decrease fuel lubricity.
That is a VERY interesting study. I have always used 16 oz. of Stanadyne or 32 oz. of Diesel Kleen per tank in my personal trucks (roughly 100 to 1), mostly to improve cetane significantly.
I am glad that I have always overdosed the fuel, as the lubricity improvemements are someone dismal using the lower dose.
I have never seen the Opti-Lube stuff, but I am going to actively search it out when my current supply of Stanadyne and Power Service are exhausted.
