Locking Differential - Ford Truck Enthusiasts Forums
Old 03-05-2003, 08:46 PM
RobertH RobertH is offline
RobertH is gaining momentum as a positive member of FTE.
Have had a GMC K1500 4X4 for 12 years and it was great. I ordered it new with the positive traction rear end. Never had a problem anywhere including the 24 inches of snow we had in NC last year.
Now, with my new 2002 X, I am worried about traction since I don't have the Limited Slip differential. Assuming that even when I lock in 4 wheel drive, I am only really pulling with 3 wheels aren't I?
Anyone know what it takes to change over to Limited Slip? Don't want to void the warranty with mod's. Would I have to have Ford to the change over? Anyone done this and any idea on costs?
Old 03-05-2003, 08:56 PM
Monsta's Avatar
Monsta Monsta is offline
Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.Monsta has a spectacular reputation.
Well actually only 2.
You can get an aftermarket LS units form many different sources. It should be around 400-600 bucks installed. If you went with a Ford unit, you may feel better about the warranty part. But you can always ask your local service mananger about using aftermarket parts and how he (as your warranty provider) feels about it.
I should say, however, that living in MA and all the snow I get, I've never had a traction problem and I do not have an LS unit or A/T tires for that matter.
The sheer weight of the Excursion is it's ally in inclement weather.
Electronic Locking Rear Differential Question Pitt4212 6.7L Power Stroke Diesel 149 11-03-2016 01:15 PM
How does the superduty 4 wheel drive actually work? zurgprot 1999 to 2016 Super Duty 31 05-14-2016 05:46 AM
locking differntial (posi) FSSF Clutch, Transmission, Differential, Axle & Transfer Case 3 02-26-2016 12:54 PM
ControlTrac 4-wheel-drive, and how it works. GlassLeather&Wood 2007 - 2014 Expedition & Navigator 24 01-24-2016 08:24 PM
How to read rear differential tag / '78 F250 dogwood74 1973 - 1979 F-100 & Larger F-Series Trucks 32 11-03-2014 03:02 PM
Tags
2005, diferential, differential, differentials, excursion, ford, locking, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
