Distributor Won't Turn '78 F350 351 - Ford Truck Enthusiasts Forums
Old 01-02-2011, 06:13 PM
therealulysses's Avatar
therealulysses therealulysses is offline
therealulysses is starting off with a positive reputation.
My timing is a little off but I can't get my distributor to turn (351, F350, '78). I loosened the distributor holding bolt and sprayed some stuff in there that's supposed to free stuck parts, ran the engine until it was warmed up good, tapped on the distributor, and tried prying upwards a little bit. Is there any chance that there is more than one bolt holding it in place? Any other suggestions?
Thanks.
Old 01-02-2011, 06:25 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Just one bolt .The dist, is aluminum & the engine is cast . Dis similar metals will cause corrosion every time , keep soaking it ...
Old 01-02-2011, 06:52 PM
impalaslayer's Avatar
impalaslayer impalaslayer is offline
impalaslayer is starting off with a positive reputation.
dissimilar metal corrosion. happened on my bronco, i tried heating the engine with a torch, no dice. i ended up heating the actual dist to get it to expanded and break free while i turned it with a wrench. once you get it free, pull it all the way out, clean the bore and dizz real good and put a new o ring on it with some anti seize.
Old 01-02-2011, 08:53 PM
LongTravelHighboy's Avatar
LongTravelHighboy LongTravelHighboy is offline
LongTravelHighboy is starting off with a positive reputation.
I have the same situation and my truck started backfiring through the carb and i think its due to the timing being off but cant adjust the distributor. What do yall suggest to use to help it break loose?
Old 01-02-2011, 09:47 PM
"Top Fuel" Bender's Avatar
"Top Fuel" Bender "Top Fuel" Bender is offline
"Top Fuel" Bender is gaining momentum as a positive member of FTE.
I actually like using Mopar rust penatrant
Marvel mystery oil works pretty good too
Like said above
keeping soaking (may take a few days)
light tapping with a hammer, some heat on the block (spray w/ penatrant , watch not to burn the truck down)
hand wire brush anywhere you can get it
lot easier to take your time then picking broken parts out of the oil pan
Old 01-03-2011, 12:59 AM
78 PEB's Avatar
78 PEB 78 PEB is offline
78 PEB is gaining momentum as a positive member of FTE.
Aero Kroil is the best rust dissolver I have found in 25+ years as a Heavy equipment mechanic. Google it and you should be able to find it. Its made by Kano Labs and is not sold in stores. You have to order it from them. It's kinda pricey but well worth it and a can goes a long way. Its available in either aerosol or gallon cans. And no I don't work for them. I just really like their product. I use nothing else. (Unless I run out of it then the first thing I do is order more.)
Old 01-03-2011, 10:12 AM
Quote:
That stuff is awesome
I really wondered if they make the mopar stuff , it smells looks works and tastes the same
Old 01-03-2011, 10:24 AM
78 PEB's Avatar
You drink oil too????? LOL I've never tried the mopar stuff but have used aero kroil for years best stuff on the planet......... Just a little side story.....I worked in a military shop in Iraq for 2 years one time........Being a smoker, I cant smell auto trans fluid to tell if it is burned, so I taste it. All the guys in the shop used to get a real kick out of watching me lick the dipstick out of HUMVEES to see if the oil was burnt..............
Old 01-03-2011, 10:41 AM
OrangeJuice OrangeJuice is offline
OrangeJuice is gaining momentum as a positive member of FTE.
I had a similar problem when I tried to pull a distributor out of an FE 390. It would not budge at all. I was tearing down this 390 and the only way I could pull it out was to remove the bolts to the intake, loosened it a bit then it popped right out. It was no biggie if you have to tear it down. The distributor hole in the front of the intake must have been a little too tight of a fit for easy removal.
OJ
Old 01-05-2011, 11:07 PM
Thanks everyone for all the great tips. If the stuff I'm using (some kind of foam, forget what it's called) doesn't work I'll try the Aero Kroil. The timing doesn't "feel" like it's off but it won't pass the smog test
Old 01-06-2011, 12:21 AM
wyoming4x4's Avatar
wyoming4x4 wyoming4x4 is offline
wyoming4x4 is gaining momentum as a positive member of FTE.wyoming4x4 is gaining momentum as a positive member of FTE.
another scenerio, worst case!
I once had a stuck distibutor and it was a twisted oil pump shaft and it flaired the end of distributor. had to pull pan and oil pump. then had to beat my MSD distributor out of engine. I was very happy to beat my new $250 ditributor out of my mudracer. Lesson learned was buy quality oil pump shaft for about $25 bucks. Almost wanted to cry. this is my worst case situation.
Old 01-06-2011, 06:43 PM
Shane in WI Shane in WI is offline
Shane in WI is starting off with a positive reputation.
Mine was really stuck in my 302 as well. I tried PB Blaster but never got it loose. I also heated w/ torch with no help.
A fellow poster suggested 1/2 automatic transmission fluid and 1/2 Acetone and that worked very well. Popped right out. Might have been partially cause I'd been working on it for a few months, but it's worth a try. Works great on loosening bolts too.
Old 01-09-2011, 05:03 PM
I used 1/2 mystery oil and 1/2 acetone. Soaked it twice and let it sit overnight. A few taps with the hammer and it was loose. All in all, 15 minutes of work. THAT IS AWESOME. It bustin loose let me adjust the timing and now the truck is running right. Thank you for the advice!
Old 01-10-2011, 12:59 PM
It was Tees77150 that told me that trick. Mine runs great now as well. Been very cold here in WI, but started right up the other day. Still a few projects to do before spring. Glad you got it set.
How do I hook up and HEI distributor? Speedymaru 1973 - 1979 F-100 & Larger F-Series Trucks 28 08-15-2016 11:44 AM
Distributor Issue D.K 1987 - 1996 F150 & Larger F-Series Trucks 4 10-19-2015 05:16 PM
Distributor Stuck crwood078 1973 - 1979 F-100 & Larger F-Series Trucks 14 07-19-2013 04:07 PM
Timing with stuck distributor? scseth 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 02-22-2011 09:44 PM
Stuck Distributor? jimbbski Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 05-21-2010 12:03 AM
Tags
1979, 302, 351, 351m, cleveland, distributor, engine, f100350, f350, fe, ford, turn, v8, wont, wrong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
