4.30 Gears from 2011 F450 for trade! - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-02-2011, 03:13 PM
MB Classics MB Classics is offline
MB Classics is starting off with a positive reputation.
Ive seen a few posts on here about folks looking for these gears and our new truck has em on em and we would actually prefer something around a 3.70 range. If anybody on here has that set and would like to swap gears please let me know!
Thanks,
Derek
P.S.
We are in the Los Angeles and Las Vegas areas on a regular basis.
Old 01-02-2011, 04:49 PM
spinella's Avatar
spinella spinella is offline
spinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to beholdspinella is a splendid one to behold
i dont need them, but 2wd or 4wd? (1 or 2 sets?)
Old 01-02-2011, 09:06 PM
brd7666's Avatar
brd7666 brd7666 is offline
brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.brd7666 has a very good reputation on FTE.
Quote:
I believe the F450 only comes in 4WD.
Old 05-17-2011, 10:35 AM
UP_There's Avatar
UP_There UP_There is offline
UP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud ofUP_There has much to be proud of
Quote:
Thanks,
Derek
P.S.
I have 3:73 gears I would trade ya. Not sure of compatibility though with the sizing. I have a 2000 F250 with the 10.25 rear diff, and Dana 50 front. I'll check into the swaps and let ya know!
Old 05-17-2011, 10:42 AM
dkf's Avatar
dkf dkf is offline
dkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to beholddkf is a splendid one to behold
Depends if its the dolled up 450 with the bed or the 450 chassis cab model.
Either way the OP should open up a classified in the classifieds section.
Old 05-17-2011, 11:25 AM
LSchicago2's Avatar
LSchicago2 LSchicago2 is offline
LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.LSchicago2 has a great reputation on FTE.
The F450 are available in 2wd/4wd Cab Chassis, and 4wd pickup models. The cab & chassis uses the big Dana 110 axle in the rear, I believe they both use the Dana 60 front axles, with at least the cab & chassis using the Super 60 series. You should be more specific as to what you have! Saying 2011 F450 is very vague.
Old 05-17-2011, 11:49 AM
cartmanea cartmanea is offline
cartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to allcartmanea is a name known to all
What engine do you have and what is the trucks intended use? You may regret the gear change down the road, and it will take thousands of miles of fuel savings to offset the cost of a gear swap.
Old 05-17-2011, 03:16 PM
JKBrad's Avatar
JKBrad JKBrad is offline
JKBrad has a very good reputation on FTE.JKBrad has a very good reputation on FTE.JKBrad has a very good reputation on FTE.JKBrad has a very good reputation on FTE.
The 450/550s and any Super Duty with 4.30s will have a Super 60 front. My F250 does.
Work / Vacation trip shadowdd Excursion - King of SUVs 25 07-12-2009 07:27 PM
Pomona swap meet kallex300 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 07-11-2008 02:30 PM
Question about Vegas bigrigfixer General NON-Automotive Conversation 17 11-14-2004 06:38 PM
Las Vegas, NV snb13 New Member Introductions 12 07-25-2004 10:40 PM
Rebate?? photonv Car/truck Buying Advice 3 07-01-2004 06:03 PM
Tags
2008, 2011, 370, 430, end, f450, f450for, ford, gears, kit, lift, lifted, rear, sall, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
