1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Clunk clunk noise
Old 05-17-2011, 02:48 AM
flyer7.3's Avatar
flyer7.3
flyer7.3 is offline
Clunk clunk noise
I have an 03 F250 7.3 with 80000 kms on it, when I do a full lock turn I get a clunk clunk clunk noise from the front end, any ideas what this might be.
Thanks
Baz.
Old 05-17-2011, 08:52 AM
WestCoastTodd's Avatar
WestCoastTodd
WestCoastTodd is offline
Thanks
Baz.
Are your hubs locked or in 4x4? Bad axle ujoints will do that.
Todd
Old 05-17-2011, 10:08 AM
SteveH-CO's Avatar
SteveH-CO
SteveH-CO is offline
If the factory ESOF hub fails to unlock, this noise will happen. Take a pair of snap ring pliers and remove the manual hub bodies on each side and repeat the test (avoid dusty roads). If the clunk is gone, then your problem is caused by a hub that failed to unlock.
If you have manual hubs, just be sure they are unlocked.
Old 05-17-2011, 01:22 PM
SDElwood's Avatar
SDElwood
SDElwood is offline
And at the same time, you probably have bad, or at least worn, axle shaft joints.
Jfountain86
08-05-2016 12:01 PM
tmyers921
06-14-2016 01:14 PM
erich545
03-24-2016 01:21 AM
kingerbinger
06-04-2015 06:10 AM
7.3lpowerstroke
10-22-2011 01:00 PM
Quick Reply: Clunk clunk noise
