Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-02-2011, 01:13 PM
nelly0524 nelly0524 is offline
Garage is empty, add now
nelly0524 is starting off with a positive reputation.
Power Window Regulator
This is my first post to this site... I have a 2008 Expedition King Ranch and just discovered that the cable to the window regulator busted... Don't know how. The cable is frayed at the bottom part of the regulator. (apologies if I'm not describing this correct) So I'm assuming the whole regulator needs to be replaced since the cable is busted, correct? Anyone have any idea what that would cost? I'm assuming the labor would cost the most, I found the part online for about $100... Any ideas or suggestions would be most appreciated! Thanks.
  #2 (permalink)
Old 01-03-2011, 03:50 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
The labor is about one hour total. So whatever rate it's at $85/hr, etc.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 01-05-2011, 07:19 AM
Harley Guy Harley Guy is offline
Harley Guy is starting off with a positive reputation.
nelly0524 - just had mine replaced last week (driver's window) under my Ford ESP. Regulator was $98.49 and labor was $118.42 (1.4 hours). Regulator part number (Ford OEM) was 9L1Z7823201A. $0 deductable Found the part online for $74.00...
Last edited by Harley Guy; 01-05-2011 at 07:23 AM. Reason: part number was wrong in original reply
  #4 (permalink)
Old 01-14-2011, 10:03 PM
ZeroTucker's Avatar
ZeroTucker ZeroTucker is offline
2004 Ford F-350
ZeroTucker is starting off with a positive reputation.
To avoid this cost: As soon as the window seems to be running slower than the others, pull the door panel off and spray some lubricant like WD-40 onto the cable while somebody runs the window up and down.
The cable hangs up inside the sleeve it runs through, overworks the motor and burns it up.
  #5 (permalink)
Old 01-18-2011, 11:57 AM
berry1234's Avatar
I agree with Zero on all accounts except the wd-40. It's not a lubricant, it's a water displacer. Use a quality white silicone lubricant on the where the white plastic guides slide up and down the metal rails.
__________________
  #6 (permalink)
Old 01-18-2011, 03:42 PM
function12's Avatar
function12 function12 is offline
function12 is starting off with a positive reputation.
You can replace them yourself. The chilton manuals have a pretty good write up. Blue painters tape will hold the window up. Just use 5-6 pieces. I replaced several on my 2000 Dodge durango. Buy one with a lifetime warranty. I could get one replaced start to finish in just under an hour. Take lot of pics with a digital camera to help yourself out. Also, I would remove the old one and take with with you to the parts store. You need to make sure your get the correct side and correct door. They are usually not interchangeable.
You will be surprised how easy they really are.
__________________
See ya,
Eric
  #7 (permalink)
Old 02-09-2011, 12:30 PM
cop on my back's Avatar
cop on my back cop on my back is offline
cop on my back is starting off with a positive reputation.
I would like to know how the door panels come off. Don't get me wrong, I can do it, but it is always nice to know if there are any hidden clips or screws before you start.
This is going to be my next project on 3 of 4 windows!
  #8 (permalink)
Old 02-12-2011, 08:43 AM
gddyup's Avatar
gddyup gddyup is offline
gddyup is gaining momentum as a positive member of FTE.gddyup is gaining momentum as a positive member of FTE.
What I like to use in situations like this is liquid graphite instead of grease or something like wd-40. Like Berry mentioned, WD-40 is not really a lubricant per sae and the thing with grease is that it attracts dirt and can get gummy as it gets contaiminated. Liquid graphite is near perfect for something like this because the small graphite particles get inside the component in the liquid suspension and then when the liquid dries, it leaves just the dry graphite all over the place as a lubricant. It takes quite a bit longer to contaiminate since there's nothing really there for dirt to stick to.
__________________
Firefighter/EMT IAFF Local 4392
"I've done a fair share of stupid things in my life, a couple of which should have put me in my grave. But here I am typing away as if I had a brain." - Craig Wilson
  #9 (permalink)
Old 02-21-2011, 09:45 PM
Well, got all 4 windows done today and what a difference. No more squeeking and fast up and down. Just sprayed some good lubricant on the cables and grease on the tracks, voila!
  #10 (permalink)
Old 02-22-2011, 11:21 AM
berry1234's Avatar
Quote:
Good job. My passenger side had a horrible squeall when rolling up. Like rock on glass. Greased it up-both tracks-BOTH SIDES OF THE TRACK-cables, pulleys, pulley shafts, etc. Runs like butter.
__________________
  #11 (permalink)
Old 02-22-2011, 04:03 PM
RI-Matt's Avatar
RI-Matt RI-Matt is offline
RI-Matt is starting off with a positive reputation.
What did you guys use for lubricant? White silicone grease or liquid graphite or ........ ???
Plan on doing this soon.
Thanks,
Matt
  #12 (permalink)
Old 02-22-2011, 06:22 PM
For grease on the tracks, I used a marine grease (blue). For the cables, I used liquid wrench's lubricant.
  #13 (permalink)
Old 02-23-2011, 11:46 AM
berry1234's Avatar
I used lithium grease for the tracks and a silicone type lubricant for the pulleys.
__________________
Tags
04, 07, 2003, 2008, 99, cable, expedition, expediton, fell, ford, power, regulator, roll, track, truck, window, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
