Do these plugs look rite for mpg ?
These are the plugs i pulled out of my 85 carbed Duraspark II . Do they look like they burned with the rite fuel mixture?.
Or do i need to adjust something in the 1 bbl carb or dizzy.
Trying to get better MPG went with
ngk v power wr5 gaped to 48
napa fa136 echlin cap $$ but it has brass pickups
napa belden max wires 8mm
napa echlin rotor w/ brass tip
What else can be done for better MPG thanks for any and all suggestions
from left is #1-#6 is right
pics out of focus so: ok for 25yr old plugs. MPG is dependent on so many variables: mechanical condition of engine, state of tune, carb cleanliness and adjustment, maintenance, gear ratios, tire size etc....mostly on how the vehicle is driven/maintained. The damn corn-alcohol we are forced to buy in gas hurts MPG too, by 3 mpg more/less. These engines are not MPG engines and have never had that reputation. If you are getting 17mpg or better about normal I'd say.
Do you have a macro feature on your camera? The button or setting is usually a flower icon. If you use that, it lets you focus clearly on close up objects.
With the pic out of focus, its really difficult to tell.
Although, as for tuning your carb for mpg, you want the plugs to be around 80% - 90% white, with an area of beige/tan around the tip. If they're fully white, it's too lean.
focus
Will try the macro next time didn't know about it. Thanks for the advice AB
The plugs are mostly white with a little tan on the tips. I thought the pic showed that.
So if the plugs burn white with a little tan/beige on the tips the carb should be set about rite "good fuel burn". rite?
btw: how old are those plugs? they look ancient considering the 'greasy buildup'. brand?
plugs
Parr4 those plugs came with the truck I have about 500 mi on them. Off topic I lived in jonestown TX. for 24 years lots of good people there nice lake too. Taxed me out of there.
It had a valve cover leak when i got the truck thats why some are greasy
I Went back with ngk wr5 v powers hope they work good.
New good wires, brass terminal cap and rotor $$, Trying for better mpg.
Planning to rebuild front end bushings then a alignment, check for dragging brakes and anything that will impede Mpg
thanks for the input.
ef150owner
15
07-31-2012 01:31 PM
