1966 steering column
Old 01-02-2011, 11:47 AM
bertke2651's Avatar
bertke2651
bertke2651 is offline
what are my options for aftermarket steering columns on my 66 Pricing???
Old 01-02-2011, 12:19 PM
garbz2's Avatar
garbz2
garbz2 is offline
Ididit makes a bolt in column. It has GM connections that will need to be converted to ford.
Not cheap, around 300 to 500 depending on options and a stock wheel will not fit.
what is the issue with your current column?
Garbz
Old 01-02-2011, 01:40 PM
bertke2651's Avatar
bertke2651
nothing really wrong with my column, but changing to automatic and would like column shift also aftermerkets look cleaner where can i get those aftermarket columns?
Old 01-02-2011, 09:35 PM
garbz2's Avatar
garbz2
garbz2 is offline
Never mind, that link was to Worm at Cen-Pen.
Here is a link to IDIDIT Dealers in the US. http://www.ididitinc.com/dealer_list...ealer_list.htm
Here is a place to start.
Garbz
Old 01-02-2011, 11:02 PM
Bill W's Avatar
Bill W
Bill W is offline
did you get the cab mounts figured out?
Old 01-03-2011, 11:29 AM
daveengelson's Avatar
daveengelson
daveengelson is offline
Probly salvage later model auto steering column from 'pick n pull' for around $50. Not sure what yr. tilt column was introduced, possibly another option, although would require refab and modification of the turn signal wiring harness, etc. Believe if donor column is in 73-79 yrs. should be able to swap mounting brackets and do away with the need to use spacers. Anyhow, food for thought.
Old 01-03-2011, 07:09 PM
bertke2651's Avatar
bertke2651
can i buy an ididit column for my application? or is it universal fit? i've looked @ their websites and don't see a truck application
Old 01-03-2011, 07:33 PM
Bill W's Avatar
Bill W
Bill W is offline
Old 01-03-2011, 08:04 PM
William's Avatar
William
William is offline
I like 78 F100 or F250 tilt. Then do an aftermarket wheel or retro fit a 53 wheel. If your truck is two wheel drive with an automatic look for the same in the local junk yards or e-bay. The 78 tilt does not have the ignition switch on the column and unless you look closley most don't know you have a tilt. The only thing I do is swap out the dash loop bracket (cut the spot welds) or you could just use spacers on the 78 loop and bolt it in.
Old 01-04-2011, 02:37 PM
musicmanbiker's Avatar
musicmanbiker
musicmanbiker is offline
Thanks for this post, I've been wondering what tilt would fit without too much change. John
Old 01-04-2011, 02:50 PM
BigMikeUGA's Avatar
BigMikeUGA
BigMikeUGA is offline
I'd like to find one that isn't in my chest like a NASCAR.
Has anyone shortened one from the dash to driver section?
Old 03-15-2012, 09:07 PM
Wichita Sam's Avatar
Wichita Sam
Wichita Sam is offline
Big Mike,
I just got my 66 and am 6'6" with the same problem. I drove it home for the first time yesterday and have smudges on my shirt from the steering wheel rubbing....
I like the stock look, but would like the wheel to set 4-6 inches closer to the dash and away from my belly.
the best,
Wichita Sam
Old 03-16-2012, 01:04 AM
The Masked Rider's Avatar
The Masked Rider
The Masked Rider is offline
I have a 74' unit in my 65' and I also cut the shaft 3' inches. I'm only 6' depending on how much I've had to drink. Works for me.
zippi
1947 and Older Ford Trucks
03-26-2017 08:04 AM
speedemon1084
02-16-2016 09:30 AM
1976GT
12-29-2015 01:38 PM
17fordguy
04-07-2015 01:23 PM
mmhoward
01-04-2011 03:32 PM
Quick Reply: 1966 steering column
