wheel an tire combo ideas
I also mini tubbed the bed thinking I was going wider.. where the tires are now would almost touch the bed wall without the tubs.. in the last picture the rear is aired down so I need a little more inside clearance.
Sam
also, here is a guide to figuring out what size you can handle
WHEEL & SUSPENSION MEASURING GUIDE
Sam
Sam
18's on the front with 245/50-18 Nitto's.
Rims: 18x9, 5.94" backspace, +.94" offset.
Mustang II IFS
20's on the rear with 295/35-20 Nitto's.
Rims: 20x10, 7.2" backspace, +1.8" offset.
Ride Tech triangulated 4-bar.
I am trusting the fronts will fit by what I have seen on this website and others.
Stock rear fenders (if my calculations are correct I won't need to widen them), I will have tubs in the bed.
Bed is 49" wide outside measurement. Allow 11" for each fender to allow for slope towards top where the tire will reach. Total width 71" outside to outside of tires. It leaves me about an inch clearance to the fenders on each side with my 9" differential.
Will have pics to post in a month or so. Installing the IFS now. Still need to tub the bed to fit it on the rear of the truck.
Mustang II IFS
i have turned the bars around (swap left/right) to move the bag closer to the chassis.
same for the upper pad.
notice the front of the arm comes just under the chassis rails..
I made the two brackets on the inside of the chassis to bolt the outer bar mounts to.
sam
