1989 f350alternator problems - Ford Truck Enthusiasts Forums
Old 01-01-2011, 04:19 PM
1968trailboss 1968trailboss is offline
1968trailboss is starting off with a positive reputation.
i have a 1989 f-350 with a 460 gas injected engine . i recently changed the batt cables the starter solenoid and batt .the amp meter is real slow to react re-when starting it will show discharge for some time and then real slowly move up to charge if you turn the jheadlights on it will go to discharge and slowly go back to charge after turning them off it is the same way with the heater blower . any body got any suggestions for a remedy?
Old 01-01-2011, 05:16 PM
Quick444's Avatar
Quick444 Quick444 is offline
Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.Quick444 has a great reputation on FTE.
Best suggestion would be to find the appropriate forum. You posted this in the 2009+ truck section.
Scan down a bit and you will find what you are looking for.
Old 01-01-2011, 05:47 PM
Racerguy's Avatar
Racerguy Racerguy is offline
Racerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to beholdRacerguy is a splendid one to behold
Welcome to FTE 1968trailboss
I've moved your question to a more appropriate forum for you.
The guys here should be able to help.
Old 01-01-2011, 07:14 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
standard problem with these year trucks. the gauge sticks in the off position. once started, give the top of the dash a smack rite above the volt gauge. the gauge should pop rite up to charge.
Old 01-01-2011, 08:06 PM
rikard rikard is offline
rikard is gaining momentum as a positive member of FTE.
Use a digital volt meter and measure what the voltage is at the battery with the engine off. It should be 12.6 to 12.9 volts DC. Start the engine. The voltage should jump up to 13.6 volts or better. The alternator is designed to produce enough to keep the voltage at this level with all of the electrical on.
Happy New Year
rikard
Old 01-01-2011, 09:42 PM
ArdWrknTrk ArdWrknTrk is online now
pedant
ArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputationArdWrknTrk has a superb reputation
Quote:
Yes, it is a problem with these clusters.
If you'd like another one with a broken lens in the upper left corner from hitting on it PM me...
Tags
1989, 350, 460, alternater, battery, charging, engine, light
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
