tsb
tsb
Can anyone give me any information on the is Technical Service Bulletin?
Make: Ford Truck
Model: F150
Year:1998
Service Bulletin #: BC2503910201
Bulletin Sequence #: 001
Summary Description: Brake popping noise from front brake caliper suddenly springing away from the upper caliper abutment and returning
Thanks
Make: Ford Truck
Model: F150
Year:1998
Thanks
tsb
That doesnt sound like a Ford TSB number. Can you check the number again? Where did you get that number from?
I dont remember ever seeing a TSB concerning the problem you're describing. There is one about the caliper pins seizing up but that wont cause a pop noise.
What kind of problems are you having?
tsb
yo,
I see that type of designation here, but for a '90 MARK VII
Service Bulletin Number: BC2503910201
Bulletin Sequence Number: 001
Date of Bulletin: 9102
NHTSA Item Number: SB022542
Make: LINCOLN
Model: MARK VII
Year: 1990
Component: BRAKES:HYDRAULIC SYSTEM
Summary: BRAKE POPPING NOISE FROM FRONT BRAKE CALIPER SUDDENLY SPRINGING AWAY FROM THE UP PER
CALIPER ABUTMENT AND RETURNING-ALL FORD RC
Make: LINCOLN
Model: MARK VII
Year: 1990
tsb
My 1988 ford f-150 is making a popping noise coming from the right wheel. It sounds like something to do with the brake to me. Anyways on this website I was looking through all of the Technichal Service Bullitens for my truck and found that. I asked ford and they said it wasn't from them. I thought someone here might know.
tsb
I didn't look through the 88 tsb's when i did the search for you. So I just went hrough the recall/tsb link (on right panel) to view the tsb's for the 88 and found what you discovered:
"Make: FORD TRUCK Model: F150 Year: 1988
Service Bulletin Number: BC2503910201 Bulletin Sequence Number: 001 Date of Bulletin: 02/91
NHTSA Item Number: 022687
Make: FORD TRUCK
BRAKE POPPING NOISE FROM FRONT BRAKE CALIPER SUDDENLY SPRINGING AWAY FROM THE UP PER CALIPER ABUTMENT AND RETURNING-ALL FORD RC..."
ask another serv dept to run that one or maybe someone here in FTE can find the compl. tsb for you.
Make: FORD TRUCK
Kyle Barrett
08-22-2010 09:06 AM
