2002 Ford Escape transmission problem no reverse please help! - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 01-01-2011, 01:17 PM
whateverittakes whateverittakes is offline
whateverittakes is starting off with a positive reputation.
I have a 2002 Ford Escape V-6 automatic 2wd. The transmission works pefect in all forward gears. When you put the truck in reverse you can feel the trans. grab in gear but when you give it gas to back up the motor just revs up and will not move. We took it to a transmission shop and they ran a diagnostic test on the trans. and said it did not give any codes. I think it might be a band or clutches. I was getting ready to pull the transmission out but I just wanted to check to make sure that their wasn't a solinoid or something simple that might cause this problem. Any help would greatly be appreciated. Also if anyone knows where I can find any info on transmisssion removal would be great. Thanks
Old 01-02-2011, 09:55 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
The reverse gear does not rely on electrical circuits or controls for engagement. Therefore, your lack of reverse indicates a mechanical or hydraulic failure. This will be a blown seal or a busted hard part, only a tear-down will tell.
Get the service manual for removal instructions. There are too many other things to address during R&R to go without for an non-experienced person.
Old 01-02-2011, 10:15 AM
Thanks for the info.
I started taking the transmission out. I can't get the back bolts out of the mount I have used impact and already broke a mac breaker bar. Any suggesttions?
Old 01-03-2011, 05:03 PM
I got the transmission out. Does anyone know where I can get the best price on a rebuild kit for it?
E4od transmission going fast in reverse Mr. Electrician 1994.5 - 1997 7.3L Power Stroke Diesel 9 07-02-2014 06:56 PM
transmission baffled??? neura Escape & Escape Hybrid 9 11-16-2012 04:31 PM
01 Escape slow to engage in drive and rev. 67Ray Escape & Escape Hybrid 5 02-25-2011 12:20 PM
2002 Ford Escape transmission problem no reverse please help! whateverittakes Clutch, Transmission, Differential, Axle & Transfer Case 0 01-01-2011 01:30 PM
1997 F450 Manual Transmission Problems fire7882 1999 to 2016 Super Duty 0 05-19-2008 10:36 AM
Tags
2002, 2003, escape, explorer, failure, ford, forward, mazda, problem, problems, reverse, slips, transmission, tribute, trouble, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
