Codes p0304 and p0316 help please!
Old 12-31-2010, 10:00 PM
Dirtymechanic's Avatar
Dirtymechanic
Dirtymechanic is offline
Can I get some help please? I am currently pulling a trailer through Joshua tree and I am stuck at the moment. Getting codes 304 and 316 on the truck. F150 2004 5.4 4x4. Replaced the coils and crankkshaft shaft sensor already today still no go. Any ideas on what to do next?
Old 01-01-2011, 07:40 AM
wildcard30's Avatar
wildcard30
wildcard30 is offline
Are you still getting the same codes?
Old 01-01-2011, 08:45 AM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
Try a set of plugs.
Old 01-01-2011, 11:42 AM
Dirtymechanic
I changed plugs over summer, even moved plugs around, as well as coils, codes I do get are p0304, p0305, p0308, p0316, even got p0174, this thing is a mess. Clean out battery, cleaned out mass air flow and intake body, waiting for compression tester, looking at fuel injectors now
Old 01-01-2011, 01:35 PM
Dirtymechanic
Still stuck
Still getting the same codes. Removed and cleaned injectors and a mess of sensors. Still the same codes. Truck runs ok by itself to get home but under a load with the trailer, no good. Could this be a compression problem?
Old 01-01-2011, 03:21 PM
Greg B's Avatar
Greg B
Greg B is offline
No. The codes show a misfire in #4, 5, and 8 cylinders. P0316 is a misfire detected on startup and P0174 is system too lean bank #2. Given the age of the truck, I'd check out the fuel system. It could be that the fuel pump or driver module are starting to give out or injectors that are going bad.
Old 01-01-2011, 04:54 PM
wildcard30's Avatar
wildcard30
+1 Also the fuel filter...
Old 01-01-2011, 08:28 PM
fordtech08's Avatar
fordtech08
fordtech08 is offline
3,5,& 8 could have low compression which would cause those codes, you need 3 things to work air, fuel, and fire
Old 03-31-2023, 08:43 PM
babyface1295's Avatar
babyface1295
babyface1295 is offline
1st Gear
did you ever figure it out?
I am currently having the same codes and issues as you had. What ended up being the culprit?
Old 04-01-2023, 03:58 PM
torq'ta 5 8's Avatar
torq'ta 5 8
torq'ta 5 8 is offline
prolly no answer, 3 post 12yrs ago and hasnt been back. Have you checked any of the suggestions above, like fuel pressure.
vivojr21
37
11-04-2023 03:37 AM
Tile man
2004 - 2008 F150
04-18-2017 08:51 PM
Brandon50394
Aerostar
09-18-2012 01:43 PM
Wolf1200
1997 - 2003 F150
05-06-2009 01:28 AM
szpieleusa
6.4L Power Stroke Diesel
04-05-2009 01:57 PM
Quick Reply: Codes p0304 and p0316 help please!
