Rear axle ident help please
I got the numbers off the tag on my rear axle and was hoping someone could help me decode it and possibly tell me what it came out of. (WBS AD2 3.00 4CA 160), so far all I could come up with is it is from 63 or 64 possible 28 spline 8.75" with a 3.0-1 gear ratio...
Yeah I have a 8 3/4 (9") out of a 71 f100 pickup with a 6 cylinder. I was totally stoked about finally finding a 9" axle from a pre 72 truck to bolt into my 51...then I found out it wasn't a "true" 9" inch by the 8 3/4 ring gear it has. I was bumbed a little but I figured it is plenty stronger than the original dana 44 and I believe that even though the ring and gear is a 8 3/4" it still has interchange ability with the 9" parts when you want to change to a different gear ratio. Mine turned out to be exactly what I wanted, a 3:70 gear.
FordNFishinLover
05-12-2010 04:34 PM
branpollard
12-23-2004 12:40 AM
