1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
2005 PSD Hard To Start Cold.
Old 12-30-2010, 01:23 PM
Built_Ford_Tough_757's Avatar
Built_Ford_Tough_757 is offline
The past two days I had problems getting started cold, I waited for the glow plugs and the truck cranked but died right away, and the only way to get it going was to floor the pedal as I was starting. Is this a comon problem when they are cold? Temps were probably in the 20*'s. Both times the block heater was not plugged in, forgot both nights to plug in.
Old 12-30-2010, 04:54 PM
gearloose1's Avatar
gearloose1
gearloose1 is offline
Don't wait for the glow plugs, go ahead and crank when the glow plug light goes off.
If you have a fuel heater (it was discontinued at some point) unplug it.
jc8825's Avatar
jc8825
jc8825 is offline
Shouldn't be. I never plug in my truck and it starts in the 20s. At least the couple of mornings it has been in the 20s.
Old 12-30-2010, 05:28 PM
mhoefer's Avatar
mhoefer
mhoefer is offline
Check for codes, I doubt your glow plugs are working or your batteries are dying, what is your voltage pre start, with glow plugs on, following startup? You should load test batteries and if they are original, replace with motorcraft 850's.
Also, are you running synthetic oil, 10w30 for winter?
Old 12-30-2010, 08:03 PM
I'm running 15W-40
Old 12-30-2010, 08:52 PM
gearloose1's Avatar
gearloose1
Add antigel and cetane boost.
Old 12-31-2010, 09:29 AM
Ok, I'll try that, thanks
Old 12-31-2010, 10:26 AM
driximus's Avatar
driximus
driximus is offline
I run 15-40 and have no problems starting in the 20's. I would look at your batteries first. then GP's and GPCM.
Old 12-31-2010, 10:54 AM
gearloose1's Avatar
gearloose1
Basically, that is what Ford spec says it ought to do.
Yes, check electrical system... voltages at different stages..
Key OFF
Key on, glow plug on, pump on
key on gp on pump off
cranking
If he is much below 9.7v on cranking.. there is a problem.
Old 12-31-2010, 11:38 AM
redford's Avatar
redford
redford is offline
Received 1,559 Likes on 908 Posts
While the urge is to blame the glow plug system or even the fuel, most of the time this happens because your batteries are old and need to be replaced.
A new battery that can hold a full charge at 77F loses half of that charge at 5F. Old batteries lose capacity, so when the thermometer drops you suddenly find the 3-5 year old battery is marginal.
Herford
12-15-2016 05:54 PM
riley431
26
03-05-2016 10:26 PM
alfaista
02-14-2016 08:42 AM
ccoppens
16
01-11-2014 01:36 AM
Josh88Ford
16
12-09-2013 06:38 PM
Quick Reply: 2005 PSD Hard To Start Cold.
