1979 Ford F-Series Truck vin decoding help - Ford Truck Enthusiasts Forums
Old 12-30-2010, 02:02 PM
2011coyote 2011coyote is offline
2011coyote is starting off with a positive reputation.
Have a 1979 Ford truck with this vin: F14HLDC8683
Also. Where are the vins located other than the drivers side door?
Old 12-30-2010, 02:44 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is online now
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
F14HLDC8683
F14=F150 4WD pick up
H=351 cu in 2bbl V8 engine
L=Michigan truck assy plant
DC8683=1979 model year sequential serial number
The VIN is also located on the frame in two places. The top right (passenger side) frame rail. The visible VIN is between the radiator and firewall usually about inline with the alternator. The hidden VIN is also top right frame rail under the cab, usually about 6"-10" behind the front cab mount.
Sometimes there is a metal buck tag screwed to the firewall, this will have the VIN.
And all trucks have a paper certification sticker on the drivers door jamb. There is a VIN on it too.
BTW welcome to FTE, lots of good knowledgeable people here.
Old 12-30-2010, 03:57 PM
Thanks for the quick response. The paper certification sticker is painted over and I'll check in the other places you described for the visible one and less visible one. The buck tag is not in place per your description. Really appreciate the decoding.
Old 12-30-2010, 04:39 PM
mikeo0o0o0's Avatar
Quote:
A lot of vehicles left the factory without a buck tag. I've got three trucks and none have a tag.
Also, sometimes the frame VINs are stamped lightly and are hard to locate/read. You'll probably need to take a wire brush to the frame to bring out the VIN.
Here is a picture of a buck tag, its attached to the firewall with a single screw.
Old 12-30-2010, 11:02 PM
The frame VIN may be the only one that is left on this particular example. The paper certification sticker is painted over. No buck tag. And the tag between the rad and the firewall roughly inline with the alternator you described is gone too. I'll have to see what I can do about locating the one on the top of right side frame rail. Probably tough to see with cab attached to the frame. Maybe a mirror will help.?.?
Old 12-31-2010, 06:34 AM
mikeo0o0o0's Avatar
The frame VINs aren't tags, the numbers are stamped into the frame rail itself. Sometimes they were stamped lightly and are difficult to see but they are there. With 30+ years of grease, road grime and crud built up you'll need to take a wire brush or a wire wheel and clean the frame to find the VIN.
And as for the hidden VIN under the cab, yeah, you'll need a mirror to see it unless you remove the cab.
Old 12-31-2010, 08:44 AM
Going to wait till the weather breaks a little and give the one stamped between the rad and fire wall a shot. It's a really decent truck. Regular cab, short bed, auto, looks like a 9" under the rear. Needs a little mechanical tlc. Trans does not start off in 1st automatically. Can manually pull the column shifter down into 1st and then it will start in 1st. Had a drivers side wheel bearing go on it. Brake pedal travels to the floor. And power steering pump is seized. The exterior is blue with 15" aluminum wheels. Has a hinged hard cover toneau cover. Windshield visor with amber running lights. Interior is in good shape too. Custom 60/40 split seats with overhead speakers.
1979 Ford F150 Frame VIN Justin Braun 1973 - 1979 F-100 & Larger F-Series Trucks 4 10-19-2016 12:32 AM
Can I put a 1979 4x2 F150 body on a 1973-79 4x4 frame Justin Braun 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-06-2016 11:08 AM
VIN Decoder for 1979 F150 ??? ford4her 1973 - 1979 F-100 & Larger F-Series Trucks 44 03-23-2014 12:44 PM
Where is the vin? skeelo 1973 - 1979 F-100 & Larger F-Series Trucks 20 10-18-2010 09:45 PM
Whats in a VIN? Sycostang67 1973 - 1979 F-100 & Larger F-Series Trucks 24 04-26-2009 10:23 PM
Tags
1979, chassis, decoding, f100, f150, f250, ford, frame, fseries, hidden, location, numbers, tag, truck, vin, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
