Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 12-30-2010, 06:44 AM
Ebonysti Ebonysti is offline
Garage is empty, add now
Ebonysti is starting off with a positive reputation.
looking for some tech help with air ride
Hi all, new to the form and looking for some tech help with air ride.
2007 Navigator L problem is have moved to a new location and the parking garage is about 2.5" lower that the truck, so you see what I am up against.
Here is what I am about to do to start, removal of the roof rack this will give me almost the 2.5" I need but I need a safety zone.
My question for the ford tech's and or the experienced members is, with the factory ford tool are you able to re-set the stock ride height an inch or more lower as your stock setting, I understand with doing this I would need to aline the truck to this new setting.
Any help or advise would be great
Thank you
  #2 (permalink)
Old 12-30-2010, 12:41 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
I would post this at flatratetech.com.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 12-30-2010, 09:32 PM
Z06PSI's Avatar
Z06PSI Z06PSI is offline
Z06PSI is starting off with a positive reputation.
If you turn the truck off before you enter, let the air bleed out, turn the suspension off, and drive in. Once you are out of the garage turn it back on. That's what we do.
__________________
Andrew, Christine, and Aidan Baker
2005 Navigator Ultimate
2002 Mil Yel ZO6 - 383 stroker 2.8L Kenne Bell and methanol.
  #4 (permalink)
Old 12-31-2010, 08:35 AM
Thanks
Thanks Berry/ZO6 will try both
Tags
air, bauer, bleed, eddie, ride, suspension
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
