What PSOM stand for with Gauge CLuster? - Ford Truck Enthusiasts Forums
Old 12-29-2010, 11:51 PM
Barry Eck Barry Eck is offline
Barry Eck is starting off with a positive reputation.
We want to know what PSOM stands for in reference to a gauge cluster?
Is it the all the gauges with the tech,oil pressure, battery, speed odometor cable is hooked up to ?
Thank you ....
Old 12-29-2010, 11:53 PM
Kapusta's Avatar
Kapusta Kapusta is offline
Kapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to allKapusta is a name known to all
Programmable Speedometer/Odometer Module
Old 12-30-2010, 12:10 AM
Kapusta,
Thank you for the quick reply, would be kind enough to give a little more information about the PSOM module where is located? what does it look like? What does a new one cost and what would a used one go for approximately.
Thank you in advance,
Old 12-30-2010, 12:17 AM
Kapusta's Avatar
I don't have much more info but running a search on this forum should yield a lot of good results.
Old 12-30-2010, 08:42 AM
subford's Avatar
subford subford is offline
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Quote:
Programmable Speedometer/Odometer Module (PSOM): A module that processes vehicle speed information for use in various electronic systems. The PSOM can be programmed to accommodate various tire and axle combinations.
The PSOM is a small computer that takes a AC voltage (Approximatly 3.5 VAC @ 30 MPH) generated by the VSS on the rear end (A variable reluctance sensor (VRS)) and uses a programmed conversion constant to convert the signal to the standard 8000 pulses per mile speed signal output and then drives the:
1. Provides information to the Speed Control Amp. for auto speed control.
2. Drives the Speedometer.
3. Keeps track of how many miles the truck has driven and sends this information to the Odometer read out.
4. Provides information to the PCM computer for the Transmission shifting, Ignition Timing and the Injector fuel control.
NO.
The PSOM:
PSOM Mounted on the back of the Speedometer.
PSOM location:
Old 12-30-2010, 11:35 AM
Kapusta's Avatar
^^^ now that's a great info!
After market gauges 'Lil-Pete 1987 - 1996 F150 & Larger F-Series Trucks 4 05-06-2016 10:03 PM
Driving without instrument cluster - 95 powerstroke KLEIMANN 1994.5 - 1997 7.3L Power Stroke Diesel 8 08-21-2015 05:05 PM
92-93 F series speedometer (psom) Bob Gervais WTB - Ford Trucks & other vehicles 2 04-06-2010 05:26 AM
PSOM/Code questions fishheds Aerostar 6 03-07-2010 10:41 AM
PSOM Programming 95centurion 1987 - 1996 F150 & Larger F-Series Trucks 1 08-18-2009 01:58 AM
Tags
1994, 92, barry, cluster, eck, f150, f250, ford, location, norton, psom, raptor, stand, std, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
