Lifting the bed
Lifting the bed
Newbie question I'm sure. Is there a common way to lift a truck bed in the driveway without help?
I'm thinking of building a derek with 4x4 lumber for uprights, 2x6 as the cross-bar and 2x4's supporting things at the ground. Then I'll use a block & tackle or come-along to lift the bed. I've already detached all the bolts (that was a pain).
Another idea is to lift it with lumber on the two hydraulic jacks I've got, then prop it up between two saw horses, then drive the truck out from under.
I'm doing this to install my '69 Mustang tank.
Here's an idea if you have an engine hoist. Go to your local metal yard. Buy a square tube that's wide enough to slip over the square tube on your engine hoist. Should be about five feet long. Drill a new hole at the end of the new tube. Run an 8 grade bolt through the hole and the chain with the hook through the same bolt. Slip the new tube over the engine hoist's tube. This will give you a longer reach. Make sure to extend the feet of the engine hoist ot the max position. Run two long straps from one side of the bed to the other, with the straps parallel to each other. Get a 4x4 piece of wood and attach it to the hook of the hoist (you may need to screw in a eye bolt or wrap a chain around it). Slip the 4x4 in between the straps and lift up. You'll then be able to adjust the hoist to find center of gravity. Lift up the bed and either slowly pull it out or move the truck forward.
Here's the set up that I made to lift the cabs off the trucks and onto the trailer by myself.
I loaded everything onto the trailer and the back of the truck with the method I described above, but tweaked to each application. The prinicple is the same, though.
Not anymore... I got it all!!!
I stripped an F6 COE of its cab and front clip in Corona, CA. I did it all by hand without any power tools. Took me almost the whole day. I hired a day laborer to help me lift the cab and the front clip onto the trailer. I left the rest of the truck on the street for the city to tow.
Before that, I picked up the F6 cab and front clip from a yard in Pomona. Luckily, they had a forklift.
I sold everything, but the F6 front clip. Still have it. The COE went to New Zealand and six months later, the buyer emailed me pictures of his finished product.
He did a great job in such a short amount of time. More than I could have ever done in years.
