Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 12-29-2010, 06:39 PM
ShayneO ShayneO is offline
Garage is empty, add now
ShayneO is starting off with a positive reputation.
Bad Injector Symptoms???
what are the symptoms of a bad injector or fuel problem??pretty new filter,just blew it out with compressor.blew out the fuel lines, not sure if the regulator is bad or if its just injectors..it misses once and a while when i drive sometimes it will do it somtimes it wont i dont have any open wires or vaccum lines everythings in good shape. brand new wires..soo??
  #2 (permalink)
Old 12-29-2010, 07:01 PM
xlt4wd90 xlt4wd90 is offline
xlt4wd90 is gaining momentum as a positive member of FTE.
Bad injectors can cause mis-fires (clogged or not opening properly) or flooding (stuck open). I once jammed up one of my injectors so badly that its cylinder did not fire at all. I ended up pulling them all out and reverse-flushing them with injector cleaner spray. Did you try running some cleaner through the gas tank?
  #3 (permalink)
Old 12-30-2010, 10:04 AM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a very good reputation on FTE.Kemicalburns has a very good reputation on FTE.Kemicalburns has a very good reputation on FTE.Kemicalburns has a very good reputation on FTE.
what vehicle is this happening to and what year?
pull codes, check fuel pressure. may need a tune up?
__________________
94 XLT 357/E4OD/Warn HS9500I
6"ProComp Stage II 35x12.5x15 BFG AT's
4.88 gears/Aussie Front/rear open
Edelbrock efi intake JBA shorty,CustomY pipe/exhaust
http://www.supermotors.org/registry/...il.php?id=4158
  #4 (permalink)
Old 01-03-2011, 05:46 PM
its a 1990 f150 with a 5.0. it hasnt been doing it lately but once and a while it would miss like it wasnt getting enough gas
  #5 (permalink)
Old 01-04-2011, 07:46 AM
timbersteel's Avatar
timbersteel timbersteel is online now
timbersteel is gaining momentum as a positive member of FTE.
X2 what Kemicalburns advised.
Get a fuel pressure gauge on the rail, and see if in fact it's delivering (X) amount of fuel without any hesistation. Mine did the same and it was the fuel pump.
__________________
1992 F-150 I6 4.9L 300 110K 4x4, SuperCab, Manual
1992 F-150 V8 302 156K 4x4, SuperCab, Auto
"He's one brick shy of a load..."
"These ideas, evaluations, opinions are representations of real-life scenarios and backed by Murphy's Law..."
"Inferior parts lead to immediate failure sooner than later..."
  #6 (permalink)
Old 01-04-2011, 05:57 PM
The engine will require more fuel while under load, so you can get a better idea of fuel pump performance if you can monitor the pressure under load, like WOT going up a steep hill.
Tags
05, 60, 69, 73, 96, 97, bad, diesel, f150, ford, injector, injectors, signs, symptoms, sysptoms, typical
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
