Factory Radio Harness/Steering wheel controls - Ford Truck Enthusiasts Forums
Old 12-29-2010, 04:30 PM
Person25 Person25 is offline
Person25 is starting off with a positive reputation.
Hey guys, Im doing a new head unit (alpine iva w203). Ive gotten to the point of getting the OEM unit out of the dash, I see that there are two harness plugs going to the back of the radio. One larger than the other.
Instead of cutting the factory harness ive purchased the aftermarket harness to connect to the factory harness. which is here......Receiver Wire Harness For select Ford, Hyundai, Lincoln, and Mercury models, 2003-up at Crutchfield.com
What I dont know what to do with is the smaller of the factory harness plugs. Is that the steering wheel control plug? if so, where do I find that harness plug so i dont have to cut those wires. Im not seeing it on crutchfield. The alpine unit doesnt require any other connections so I am a bit stumped as to what i could be missing. Also, I did buy a SWI-JACK made by PAC, ive begun reading those instructions, but I defer to the guys here first. The harness on the SWI JACK plugs into the alpine unit, but the ends going to the steering wheel controls are just stripped wires. I really dont want to have to spilice any wires. any input?
Old 12-31-2010, 08:32 PM
pidaster pidaster is offline
pidaster is starting off with a positive reputation.
That is the correct harness for your truck. The second harness is not needed.
As for the SW control, you will have to tap at least one wire for that. Follow the instructions for connecting and programming.
Old 12-31-2010, 10:46 PM
Its jsut weird how there is a whole other harness that isnt needed now is just hanging out there.
As for the steeringwheel controls, I had to take the harness I got from crutchfield and remove one of the unused pins and put it in pin19 on the ford24 harness. that pin was then grounded into the harness. From the PAC-JACK you only need the power, ground and the control wire for Ford, which was white. That plugs into pin18 on the ford24 harness. The directions werent very clear, it took me and a friend about an hour to program the unit. but it works, so if anyone reads this thread looking to do this procedure and needs a hand let me know.
Old 12-31-2010, 10:51 PM
Quote:
It's that way on many Fords from '97 up. Some of them, such as my '07, it's for the Sirius tuner and AUX input. My aftermarket unit doesn't need anything in that harness therefore it doesn't get used.
Old 01-01-2011, 12:49 PM
WD401 WD401 is offline
WD401 is starting off with a positive reputation.
PAC SWI-JACK
Did you install this on a new 2011 Super Duty? I have a 2011 Super Duty and there is no wire in pin 18 on the wiring harness on the truck.
Old 01-01-2011, 05:51 PM
Quote:
No, its an 08 f150. There was a wire for me in pin18, but i did have to move an unused pin into pin19 as i needed a ground through that pin according to the directions. What really helped me identify exactly what pin controls what function on the factory harness was the aftermarket harness i purchased. Each wire on the aftermarket harness has the function printed on the wire itself, and the colors match up perfectly. So if your looking to do a new headunit and you arnt willing to cut the factory harness on the 11' look into the aftermarket harness adapter.
aftermarket stereo abyars111 Expedition & Navigator 0 12-03-2015 09:22 PM
Steering Wheel controls not working mlux2008 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 5 11-05-2013 04:59 PM
Mods Continued: Pioneer Navigation Install bridge 6.7L Power Stroke Diesel 19 10-05-2012 08:44 PM
F150 08 Radio and Steering Wheel control harness?? Person25 Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 2 01-03-2011 12:08 PM
Help with Kenwood DDX7015 install in 2004 noahr 2004 - 2008 F150 5 06-07-2004 06:34 PM
Tags
1972, 2008, connector, control, controls, f100, f150, factory, ford, harness, radio, steering, swap, swi, truck, wheel
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Fordģ is a registered trademark of the Ford Motor Company.
