cold cranking amps
Are your grounds and battery cables the correct size? Are the connections tight for grounds and cables? Some aftermarket battery cable terminals don't match the battery stud angles. (Surfaces don't match.) When someone turns the key to start, does the starter solenold sound strong or weak? Positive starter connection tight? chuck
on
You have something else going on there since 650 CCA should be sufficient. I always run the battery ground directly to the engine not the body. A bell housing or transmission mounting bolt is a great place. Make sure the connections are good and tight. Starters can be bad right out of the box too. I'm running a group 65 650 CCA battery with a 350 Chevy and it starts fine...
Also check your neutral safety switch is functioning correctly - I just remembered I had a slight issue with mine that caused a few problems and once I'd reset it the problem dissappeared straight away.
Also, have you changed any wiring or was the wiring you already had correct for the 302?
There is no safety switch. I'm assuming I need that for inspection right now all I do is hit the ignition with no key and The motor is turning over now. It was the grounds... I grounded the motor and the battery to thr frame rail and made sure it was bare metal. Now it turns but won't start.... On to the fuel and redoing the points on the distributor. And hopefully I get that rigjht. Oh. And the wiring was already done for the 302. The previous owner drove it around for a while before I got the truck.
