02 Explorer-Where to find and buy a replacement clutch!!!
My son just purchased a 2002 explorer stx with a 5 speed standard. I've contacted all the local parts stores and the ford dealership and no luck finding the correct clutch assembly to replace it with. Ford no longer carrys it(no listing, even individual parts) Any HELP will be apprieciated. Thanks Scott
I've got more info:
Got the clutch pulled, it's a 10 inch disc,1-1/8 inch shaft,26 spline that bolts to a duel mass flywheel. The LUK clutch number is 07-169, and another clutch kit number is MU721231DK. No luck with anything around here. Any HELP would be welcome. How hard is it to swap a ranger tranny and transfer?
2. Ship (overnight) your entire clutch assembly to them
3. in 24 hours it will be on it's way back to you
or find a clutch rebuilder in your area- they should provide a 24 hr turn around as well
Found replacement!
After alot of no I don't have a 26 spline clutch kit, I called southland clutch they made a solid flywheel matched a disc and presure plate, tested it in a 02 and now sells it to the public. southlandclutch.com - San Diego Clutches, Clutch Kits, Performance Clutch Solutions Very helpful and knowageable people. Seams Ford experimented with about 1000 explorers and use this tranny and duel mass flywheel then dropped the idea. Thanks Everyone Scott
2002 Explorer 4 door Manual transmission. We have developed and tested a solid flywheel clutch kit. Kit includes Solid flywheel, 26 spline sprung disc,pressure plate, pilot bearing, pressure plate bolts, alignment tool. We also stock the internal slave (it is still available from Ford). Kits are in stock (California). Please call for pricing. Contact southlandclutch.com - San Diego Clutches, Clutch Kits, Performance Clutch Solutions, 800-310-2588. Dan or Kim
Billy Brethren
06-16-2011 11:56 AM
fhipper
11-17-2009 01:21 AM
