A weak link in the design - Ford Truck Enthusiasts Forums
Vendor Specials, Discounts, Product Announcements & Group Buys This is the place to check out offers from FTE sponsors. Non-sponsor vendors may not post here.
Old 12-29-2010, 01:40 PM
ADDFord ADDFord is offline
Former Vendor
ADDFord is starting off with a positive reputation.
Hey everyone.
One of the major issues that we are seeing from customers are the rear abs sensor's snapping. They are located on the front side of the axel and seem to be catching rocks, debris, mud, etc. because they are unprotected they are becoming brittle and weak, or taking impacts from rocks or simply snagging stuff. So we made a simple quick fix for cheap.
These abs gaurds take about 5 min total to put on and provide protection completely around the sensor.
We also include a new Grade 10 bolts which is a big leap from the stock grade 5 bolt.
We are selling these for $50 shipped.
This includes
2 ABS gaurds, coated, tig welded, built from 120. wall dom
2 grade bolts
and shipped
The fix from Ford is $500. Our solution is abs gaurds for $50
Old 12-29-2010, 01:46 PM
Chug Chug is offline
Chug is starting off with a positive reputation.
Nice looking piece you made there. I have one question. Are you seeing these snapped sensors mostly on trucks that are driven off road and through snow, or is this happening to trucks that are driven strictly on road as well?
Old 12-29-2010, 01:55 PM
Former Vendor
I'd say both. Offroad because of larger rocks and debris hitting it.
They also just become brittle after about a year so on road truck from back east where it snows and the roads get salted and west where it is really hot come in about 50% of the time. The other 50% is offroad.
Old 12-30-2010, 10:53 AM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
That's pretty innovative.
Old 12-30-2010, 11:52 AM
Former Vendor
Thanks.
It's very easy to install and saves a fortune if it breaks. Just something simple to help out.
Old 12-30-2010, 11:58 AM
jmmec jmmec is offline
jmmec is starting off with a positive reputation.
Do you know if the same problem can also occur on the 2011 F150s (same design)? I do a lot of offroad driving.
Thanks
Old 01-02-2011, 01:33 PM
Former Vendor
Yes, It is the same design so the issue is the same.
You can see in the pic that the sensor has already took a beating and that is a 6 month old truck.
Old 01-02-2011, 02:11 PM
efx4's Avatar
efx4 efx4 is offline
efx4 is gaining momentum as a positive member of FTE.efx4 is gaining momentum as a positive member of FTE.
Thanks for the heads up and solution ADDFORD. Some of us actually go off road in our trucks, and in my case, live in the salty and snowy NE so this is real good info.
Old 01-02-2011, 03:40 PM
johndeerefarmer's Avatar
johndeerefarmer johndeerefarmer is online now
johndeerefarmer has a good reputation on FTE.johndeerefarmer has a good reputation on FTE.johndeerefarmer has a good reputation on FTE.
Only thing I see wrong with it is that the cable will chaff against the edge of the tubing. You need some kind of rubber grommet that goes in the end for it to rub against.
Old 01-05-2011, 03:23 PM
Former Vendor
Thanks for the orders so far everyone. Please post pics and comments once you install.
We have plenty more in stock and ready to go.
Old 01-05-2011, 05:42 PM
FUZZYDP FUZZYDP is offline
FUZZYDP is starting off with a positive reputation.
Quote:
I agree. But the cable is still exposed for sticks or rocks to catch it?
Old 01-06-2011, 06:54 AM
fonefiddy fonefiddy is offline
fonefiddy is gaining momentum as a positive member of FTE.fonefiddy is gaining momentum as a positive member of FTE.
Nothing a piece of vacuum line split down one side couldn't fix?
Old 01-06-2011, 12:44 PM
astraelraen astraelraen is offline
astraelraen is starting off with a positive reputation.
I did some medium offroading a few weeks ago through some mud/small rocks and the truck came away covered.
I noticed the TCS light came on and stayed on indicating there was a problem somewhere in the system. (I did not turn it off)
The light went on and off randomly throughout the day, but it has stayed off since. I wonder if maybe one of these sensors got knocked loose or something.
Old 01-10-2011, 12:57 PM
Former Vendor
So far we haven't had any problems with the cable being rubbed or breaking with our gaurd on it. These have been out for 6 months so I will continue to post follow ups if they should break.
Old 01-10-2011, 04:04 PM
Krewat's Avatar
Krewat Krewat is offline
Krewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputationKrewat has a superb reputation
Thread moved to Vendor Product Announcements forum.
OEM Skid Plates Installation bives 1999 to 2016 Super Duty 36 07-06-2015 09:21 PM
Mud Flaps baker51 Australia Chapter 3 12-11-2014 08:49 PM
ABS Gaurd for the easily broken abs sensor ADDFord 2010 - 2014 Ford SVT F150 Raptor 0 12-29-2010 03:29 PM
Bull Bar / Brush Gaurd to protect all those coolers? rocke36 1999 to 2016 Super Duty 24 01-15-2010 07:29 PM
cow killer rupejosh Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 32 02-06-2009 08:40 PM
Tags
73, design, duty, ford, link, links, offroadin, super, weak
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
