My redneck exhaust leak test
Old 12-29-2010, 08:35 AM
Kert0307's Avatar
Kert0307
Kert0307 is offline
After finishing up my EGR delete this last weekend (I did the Custom Diesel full EGR cooler delete it's a sinister clone) I had a hissing sound coming from the engine compartment and was about 5psi low on boost. I thought that the leak was either exhaust manifold/y-pipe related or intake manifold gasket related, but was unable to tell where when the truck was running. I came up with a redneck way to check the exhaust system for leaks to rule it out. Enjoy
"Tools" needed...
-Smoke bomb
-Duct tape
-Air compressor with regulator and hose
Directions:
1. Prep tailpipe by wrapping it with duct tape and progressively extending the duct tape out making a 5" duct tape extension to the tail pipe. Set compressor regulator to 5 psi.
2. Light smoke bomb and place into tail pipe.
3. Get air hose with 5psi of air flowing out of it and put it in the tail pipe. Use the duct tape "extension" to compress around the air hose to seal the hose-tailpipe connection.
4. Examine exhaust connections for smoke.
5. After leak is found dispose of "used tools."
Old 12-29-2010, 08:41 AM
Maxium4x4's Avatar
Maxium4x4
Maxium4x4 is online now
Received 3,392 Likes on 2,089 Posts
Well, did it work?
Old 12-29-2010, 08:43 AM
gearloose1's Avatar
gearloose1
gearloose1 is offline
I am in the market for a new muffler after the equivalent of that test (the morning white smoke at my temns).
Any advice for cheap parts?
Old 12-29-2010, 08:48 AM
Maxium4x4's Avatar
Maxium4x4
A muffler usually has a weep hole for condensation to run out, you may be seeing this in cold temps when you first start the truck. Just a thought.
Old 12-29-2010, 08:57 AM
gearloose1's Avatar
gearloose1
Thanks John... the seam on the side of the muffler is where it is... sigh...
High corrosion environment / road salt.
Old 12-29-2010, 09:02 AM
Maxium4x4's Avatar
Maxium4x4
I have the Magnaflow stainless, been holding up to the salt brine they use here.....so far so good.
Old 12-29-2010, 09:05 AM
Kert0307's Avatar
Kert0307
Kert0307 is offline
Originally Posted by Maxium4x4
Well, did it work?
Yup, it worked great. Found a couple leaks. I got them all taken care and the hissing is gone! Intake gaskets seem to be holding.
Old 12-29-2010, 09:11 AM
Maxium4x4's Avatar
Maxium4x4
The end result is all that counts.....good job and inventive way to solving a problem. Another fine example of Duct Tape 101
Old 12-29-2010, 11:37 AM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
Great idea!
Kert, hey, didn't you play MacGyver on tv?
Old 12-29-2010, 05:10 PM
davidkstyler's Avatar
davidkstyler
davidkstyler is offline
Sounds like another recent suggestion.
Unplug glowplugs.
Stuff rag in tailpipe.
Crank engine.
Look for smoke.
Old 12-30-2010, 09:30 AM
Misky6.0's Avatar
Misky6.0
Misky6.0 is offline
David,
close, but I would suspect "some" of us would end up
breaking a connector/boot. Keep it simple is rule #1.
Sort of like DRs, above all do no harm.
Old 12-30-2010, 09:54 AM
davidkstyler
Originally Posted by Misky6.0
David,
Hey, I didn't say that was the best way! The post's title was "My Redneck Exhaust Leak Test".
The first rule in any redneck contest is "Hold my beer and watch this!"
1986F150six
13
03-13-2017 09:30 AM
phantomphixer
04-04-2015 01:21 PM
kornfanjoe
12-29-2013 05:39 PM
berick
06-18-2009 06:55 PM
Quick Reply: My redneck exhaust leak test
