Did any 351's come with an AOD from the factory?
Make sure the torque convertor is engaged all the way. You have to push and turn over and over till it finally clunks in all the way. I don't know how many clunks it takes for a AOD, but I bet at least 3. When it's right, you should have to actually pull the torque convertor forward about 1/2 inch so you can start the nuts or bolts on the torque convertor.
Yes, AOD uses the same flexplate as the C4, you'll need the 168 tooth (or whichever was the biggest one they made). Look for that flexplate for the 351/C4 combo or a pre-81 302/C4 combo, 302's had the same balance as the 351 until '81. Seem to remember hearing the 351 Clevelands were the same as well.
6inarowmakeitgo
32
05-05-2022 09:56 PM
ridinginstyle
09-21-2015 03:06 AM
Stewart_H
12-04-2010 07:02 AM
smashclash
10-01-2010 11:54 PM
