Did any 351's come with an AOD from the factory? - Page 2 - Ford Truck Enthusiasts Forums
Old 06-30-2014, 06:08 PM
Franklin2's Avatar
Franklin2 Franklin2 is online now
Franklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant futureFranklin2 has a brilliant future
Quote:
Originally Posted by Ab73ford View Post
what flex plate are you running with your 351W AOD ? i am tring to do the swap and i am have trouble geting it bolted up right. the flex plate and torque converter are pushing each other.
Make sure the torque convertor is engaged all the way. You have to push and turn over and over till it finally clunks in all the way. I don't know how many clunks it takes for a AOD, but I bet at least 3. When it's right, you should have to actually pull the torque convertor forward about 1/2 inch so you can start the nuts or bolts on the torque convertor.
Old 07-01-2014, 06:16 AM
Ranger80's Avatar
Ranger80 Ranger80 is offline
Ranger80 is starting off with a positive reputation.
Yes, AOD uses the same flexplate as the C4, you'll need the 168 tooth (or whichever was the biggest one they made). Look for that flexplate for the 351/C4 combo or a pre-81 302/C4 combo, 302's had the same balance as the 351 until '81. Seem to remember hearing the 351 Clevelands were the same as well.
test BOSSY 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-26-2014 10:07 PM
facts and info of the 240-300 6inarowmakeitgo Ford Inline Six, 200, 250, 4.9L / 300 20 05-04-2014 12:06 AM
1997 F-250 460 5-speed etree 1987 - 1996 F150 & Larger F-Series Trucks 13 06-02-2011 12:20 AM
Horsepower ratings, Interesting shooer 1973 - 1979 F-100 & Larger F-Series Trucks 2 01-16-2011 07:11 PM
Engine Specifications for 80-86 Trucks smashclash 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 10-02-2010 12:54 AM
Tags
255, 351s, 352, bronco, cid, f250s, factory, ford, form, motor, putting, start, v8, windsor, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
