power lift tailgate? - Ford Truck Enthusiasts Forums
Old 12-28-2010, 05:22 PM
offroad_x's Avatar
offroad_x offroad_x is offline
offroad_x is gaining momentum as a positive member of FTE.
Anyone ever modify their rear lift gate to open automatically? Or was this an option on any year? My wife and daughter can't lift the rear hatch up because it is too heavy. I would like to somehow rig a hydraulic lift that is remote controlled like some of the newer vans and crossovers. Anyone done this?
Old 12-28-2010, 05:29 PM
jh818's Avatar
jh818 jh818 is offline
jh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputationjh818 has a superb reputation
You may need to change your struts. They may be worn out.
Old 12-28-2010, 05:30 PM
aortizexcursion's Avatar
aortizexcursion aortizexcursion is offline
aortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputationaortizexcursion has a superb reputation
I agree with that suggestion.
Old 12-28-2010, 05:34 PM
offroad_x's Avatar
I changed them recently. The originals would not hold the hatch up. With the new ones it opens fine once the door is open an inch or more. But that initial open requires a really strong tug.
Old 12-29-2010, 11:45 PM
offroad_x's Avatar
Hmm....I am guessing no one has done this yet. I have searched the forums, and haven't seen a mention of it. I think I'll have to fabricate something.......
Old 12-29-2010, 11:51 PM
Looks like you're going to have to be the first to try this out. If you get something to work, I'm sure a few will be interested.
Old 12-30-2010, 12:00 AM
delano0512 delano0512 is offline
delano0512 is starting off with a positive reputation.
I was thinking of doing the same thing, I saw my cousins Quest and it looks like a motor controled at the hatch. I was thinking of buying one from the scrap yard and moding it to work on the Excursion. I have seen others from I think it was Dodge that was a track system which I think would be to much modification involved.
Old 12-30-2010, 03:46 AM
ford_model'a''s Avatar
ford_model'a' ford_model'a' is offline
ford_model'a' is gaining momentum as a positive member of FTE.
The Ford Flex has a Power Rear Hatch and my be a good candidate as a parts donor.
Old 12-30-2010, 03:35 PM
dcf4x4's Avatar
dcf4x4 dcf4x4 is offline
dcf4x4 has a good reputation on FTE.dcf4x4 has a good reputation on FTE.
In some of the crazy car magazines (ie lowrider, etc) they have door poppers.
That is only one specific company. It was the first that came up on google search.
I had a friend with shaved handles on his mustang and all he did was push a button and out popped the doors about 4 inches.
It's not to hard to install them, and probably much easier than a motor.
Old 12-30-2010, 03:39 PM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
You can add the actuator so once the hatch is released the actuator would raise and lower it. Getting it to latch back may be tricky. This site has linear actuators which look very similar to the one which was on my 07 Expy.
Buy Linear Actuators, Electric Linear Actuators, DC Linear Actuators - Electric Linear : Miniature Linear Actuators : DC Actuators : ProgressiveAutomations.com
Old 03-02-2011, 04:31 PM
offroad_x's Avatar
Sorry for the delayed response. I got busy with things, and didn't even see it.
This is a great suggestion. Thanks for the link...I'll check it out!
Old 03-02-2011, 04:33 PM
offroad_x's Avatar
I was thinking the door popper was a good idea. That alone would be enough to get things started. As it is, everyone in the family thinks the rear hatch is still locked. If it popped open..that would make it easy.
looking for factory 2" rear lift blocks rdmobile Colorado Chapter 3 01-05-2015 10:20 PM
Inside lift gate release pkthomas Excursion - King of SUVs 0 05-13-2014 02:38 PM
Front level lift rews2 1967 - 1972 F-100 & Larger F-Series Trucks 4 04-14-2014 09:43 PM
maintaining factory rake with lift shademt Offroad & 4x4 2 02-16-2014 07:40 PM
1976 f150 lift White76 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-06-2011 08:03 PM
Tags
2002, aftermarket, automatic, door, duty, electric, excursion, ford, hatch, hatches, heavy, lift, poppers, power, rear, suv, tailgate, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
