brake line failure - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
brake line failure
Old 12-28-2010, 04:38 PM
adam10 adam10 is offline
adam10 is starting off with a positive reputation.
brake line failure
had my first brake line blowout/rust out yesterday.backed down my boat ramp at the river to go hunting.after unloading the boat the brake pedal goes to the floor.what a great time for it to blowout!at least my buddy was there his 4 wheel drive to pull the boat back out after we were done.turns out the whole line was rusted from the connection at the engine compartment back to the rearend.they outta make them out of stainless or something.
Old 12-28-2010, 04:54 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
You can use the emergency/parking brake for these emergencies.
Replacing the brake lines with stainless steel lines will prevent future problems.
Old 12-28-2010, 07:55 PM
mwsF250 mwsF250 is offline
mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.mwsF250 has a great reputation on FTE.
I have been a proponent of "rust belt" and "non rust belt" equipped vehicles for a while now. Those of us in the mild and salt free climes don't need the protection (and COST!) of all the rust resistant materials and coatings you guys do - whereas you could use a lot more.
Old 12-28-2010, 10:40 PM
Snowseeker's Avatar
Snowseeker Snowseeker is offline
Snowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputationSnowseeker has a superb reputation
For years I have questioned why vehicle manufacturers aren't demanded to use stainless brake lines. It is a huge safety deal.
Old 12-28-2010, 11:51 PM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
High corrosion areas are not limited to salt states, but also coastal areas.
Brake lines should be inspected every time a brake job is done.
Even stainless steel rusts.
Old 12-29-2010, 12:01 AM
Snowseeker's Avatar
Quote:
If it is low grade.
Old 12-29-2010, 12:07 AM
99f350sd 99f350sd is offline
99f350sd has a good reputation on FTE.99f350sd has a good reputation on FTE.
There is this new brake line out now for a couple years. It doesn't rust and bends nice and flares even better..Its got a light copper color..you can bend into anything with your hands..
Dick
Old 12-29-2010, 10:29 AM
Snowseeker's Avatar
^ Is it just copper coated steel?
Old 12-29-2010, 12:32 PM
Not steel. Its a copper nickel mix I think.. I will get the name,, brand for you.
Austin Healey brake line kit
Copper.org: Applications: Automotive - Copper-Nickel Automotive Vehicle Brake Tubing
Search on that stuff. Most parts places carry it now...
Dick
Old 12-29-2010, 01:22 PM
Quote:
Originally Posted by Snowseeker View Post
If it is low grade.
Or galvanic corrosion when it is mounted against dissimilar metals...
Nothing is forever.
Old 12-29-2010, 03:16 PM
It is for a very small percentage of the population - namely those people who keep vehicles 10+ years in high salt climates and don't inspect on a regular basis. But a non-issue for the vast majority of us. Even my 40 year old vehicle has very, very little rust on even the uncoated mild steel components.
Personally, if legislation is determined to be the answer (and I don't think it is...):
Rather than requiring higher cost materials for all, I would prefer legislation to force people in high risk areas to inspect and repair their vehicles. There is a lot more at risk than just brake lines. Or take to the Japanese extreme and require replacement.
Old 12-29-2010, 03:27 PM
You'd laugh to hear I claimed on the perforation warranty!
Hence, I am developing a treatment system that will essentially, stop rust cold for 3 to 5 years at a time, once applied.
Old 12-29-2010, 03:35 PM
Nope! It just reminds me of one of the reasons I put up with the (bountiful) negatives of living where I do! When I get a vehicle, I tend to keep it a while. Most have well over 300K before I let them go. Well, except motorcycles... The last one only had 80K - but that was because my nephew wanted it so bad.
Rust? Whazzat?
Old 12-29-2010, 05:46 PM
Snowseeker's Avatar
Dick
Interesting! Thanks much!
Old 12-29-2010, 05:49 PM
Snowseeker's Avatar
Nothing is forever.
Which should only be at the caliper and in which case the caliper should be at the other end of a rubber hose.
need parts to repare passenger rear wheel well yidakimason Excursion - King of SUVs 4 03-31-2015 04:58 PM
LR Tire Blowout, Heater Core Lines Damaged OSHS 1968-2013 Full Size Vans 6 06-20-2014 12:49 AM
Please Watch! Brake Hose Blowout Inspection makuloco2000 Escape & Escape Hybrid 5 03-08-2014 08:45 AM
My '76 F-100 Project spiritof76 1973 - 1979 F-100 & Larger F-Series Trucks 19 11-18-2013 06:59 PM
Break line blowout between fuel tank and frame portsample 1999 - 2003 7.3L Power Stroke Diesel 11 05-05-2012 12:44 PM
Tags
2000, blowout, brake, copper, cost, duty, f250, failure, ford, hose, line, lines, nickel, replacement, rusty, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
