1997 7.5L plug wire routing - Ford Truck Enthusiasts Forums
Old 12-28-2010, 12:45 PM
jjsfrd's Avatar
jjsfrd jjsfrd is offline
jjsfrd is starting off with a positive reputation.
The truck: 1997 F250HD 4X4 7.5L E4OD, 149k miles.
So, I've been reading about spark plug wire routing as a check for intermittent missing. I have searched high and low and am unable to find the wire routing diagram for the '97 460. Hopefully someone here has one as I am having some symptoms. I don't know if they are related to the wiring but here are some symptoms I have been having:
1. Not all the time but occasionally it will crank for 4-5 seconds before starting, other times it starts immediately. And it does it when it is cold or at temp. Also, and only occasionally, when it starts it sputters for a few seconds and then idles at normal RPM smoothly.
2. Occasionally when stopped at a light or waiting in gear it will sputter like it wants to die but comes back to normal RPM.
Thanks in advance,
J
Old 12-28-2010, 04:45 PM
rla2005's Avatar
rla2005 rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
This 7.5L plug wiring illustration may help you out:
The Idle Air Control is known to clog up with deposits on this vintage truck. Cleaning it may also help your issues as well.
Old 12-28-2010, 09:51 PM
jjsfrd's Avatar
Thanks, but, I'm looking for one like this:
I want to know if there are any wires in particular that need to be kept separated.
J
Old 12-29-2010, 03:49 AM
rla2005's Avatar
My manual shows the firing order for a 7.5L engine is 1-5-4-2-6-3-7-8. I suggest you keep the wires for 4&2 as well as 7&8 as far apart as possible. This will help prevent cross-fire like the routing illustrated in the photo you posted for the 5.0L engine,
Please help! 96 f150 302 hard start when warm Shovelheadnick 1987 - 1996 F150 & Larger F-Series Trucks 4 11-05-2016 10:43 AM
Intermittent problem Skyhawk Greg 1994.5 - 1997 7.3L Power Stroke Diesel 73 09-15-2014 10:29 AM
Sputtering and coughing-speed related WIKD Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 0 08-19-2014 07:28 AM
F-150 Sputters and Stalls brewscrew 1997 - 2003 F150 8 07-15-2014 07:27 PM
Plug Wire routing Old_Paint 1987 - 1996 F150 & Larger F-Series Trucks 7 08-26-2006 05:12 AM
Tags
1997, 460, 5l, 75l, 97, engine, f150, f250, ford, plug, routing, setting, spark, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
