the retirn of my helper aka start'em young and a couple of pics .
got some things accomplished today on bessie , whilst awaiting the engine plate to pull the flatty , and drop the trans etc, so i can push her out and bring the good frame back home . took the valves back out , and pulled the lifters which the picture doesn't do justice guy's ... they don't show a freaking bit of wear , and the cam again the pic doesnt do it justice , is like new !!!! it's a factory rebuild and she cant have many miles on her ! the cam despite the p.o's saying it was aftermarket , was a factory 8ba . i have an 8cm merc to replace her . the last photo of the intake is the ungainly appearance of it the 2 jet with the adaptor . the reason i am looking for another merc intake ................ oh and yea the intake , timing cover etc, etc, are going in and being glass bead blasted to clean 'em ............Attachment 31250
Attachment 31251
Attachment 31251
Attachment 31252
Attachment 31253
Attachment 31254p.s this lil helper is the one who claims the 53 is hers and she is driving it when she turns 16 . i got 9 years to find her something else ............
Attachment 31253
modify intake?
Has anyone set one of those manifolds on a Bridgeport and machined a new carb base on the top? it looks like there may be enough material in the original manifold to modify to somthing better than the original. Are there water passages in the manifold? I know nothing about flatties (I like em big).
No water passages in the stock manifolds. A very early Eddie Meyer intake had a passage under the carburetor base to warm the charge.
Haven't heard of anyone doing any machine work on one. I've seen pictures of manifolds that people welded a 4 bolt plate in place of the 3 bolt. Came complete with birdcrap welds!
I've wondered about opening up the stocker too, but remember they all had exhaust crossover passages around the two runners. As cheap as cast iron manifolds are, it couldn't hurt to give it a try.
The aftermarket cams back in the day were frequently re-ground OEM cams, so it could be an aftermarket cam. Check the lift against manual specs.
