P/N for E-Brake Cable -1966 F100 SWB F100 4x4 352
Old 06-22-2014, 09:10 PM
mosigndude's Avatar
mosigndude
mosigndude is offline
ND or others, I believe I have the right P/N for the 2853 E-Brake cable from the cab to the rear of the truck (C6TZ-2853-B) it is about 85-86" long......do you guys know of any availability for this part? Thanks, m.
Old 06-23-2014, 09:39 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
Here's a 5.5 year old thread where ND gives some advise.
https://www.ford-trucks.com/forums/8...-f100-4x4.html
What I'm curious about is why they don't list anything different for 115" versus 129" wheelbase for the 1966 F100 4x4. It doesn't seem like your short wheelbase would use the same cables as the long wheelbase like Ferari, for example, as seen here.
Ford Truck Enthusiasts Forums - View Single Post - What Have You Done With Your Truck Today
Same front makes sense, but seems like backs would be different at least.
Old 06-23-2014, 09:56 AM
schoo's Avatar
schoo
schoo is offline
I had my cables made at California push pull a tractor cable supply maker ck out one near you tractors use a lot of cables
Old 06-23-2014, 10:27 AM
TA455HO's Avatar
TA455HO
TA455HO is offline
Roy, how much to have your cables made there? Did you have them make front and both rears? Did you have to send them your originals?
The front cable for my F250 2x4 Camper Special Ranger is still available NOS, but the rears are one year only and unique to the 12" x 2.5" BX brakes that were on the Camper Special or H/D brakes option. I thought I was going to have to get some made but then an NOS set showed up on eBay. Different left/right but guy in Canada had an original set.
But, I'll probably have to get some made for one of the other trucks in the future.
Old 06-23-2014, 01:14 PM
schoo's Avatar
schoo
schoo is offline
Yes I sent the old ones to them I'm in Tucson my catalog that they gave me is at home or I could put their phone # on here but most tractor repair shop have a push pull out fit that can make them
The out fit I used is California push pull in Chico
Old 06-23-2014, 01:21 PM
schoo's Avatar
schoo
schoo is offline
I may have my old ones in the shop if you need a pattern not sure where
Old 06-24-2014, 12:57 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
C6TZ-2853-B .. Front Parking Brake Cable-85" long / Obsolete
1966 F100 4WD / No Ford dealer or obsolete parts vendor has any.
Old 06-24-2014, 09:30 PM
mosigndude's Avatar
mosigndude
Guys, thanks.....thanks ND for P/N confirmation, I will monitor ebay and the parts websites looking for this cable, if anyone knows of one let me know........I will work on restoring the one from the truck if I can't find it in next few weeks...............again, thanks, m
brider
11-06-2010 10:05 AM
terryk78
01-10-2010 07:20 AM
HardFordCore
10-13-2004 02:27 AM
Kai
25
10-07-2003 09:44 PM
Quick Reply: P/N for E-Brake Cable -1966 F100 SWB F100 4x4 352
