How to: convert the reproduction core support for '66 use - Page 2 - Ford Truck Enthusiasts Forums
Old 09-10-2013, 07:56 AM
rderr rderr is offline
rderr is starting off with a positive reputation.
Did you ever find out if the 65 2wd core support was a better option to go with? I am in the exact same situation. I have a 66 2wd with a bad core support. I would rather replace it even if it means some mods are necessary to make the new support work.
Thanks,
Rick
Old 09-10-2013, 07:18 PM
tschmitt tschmitt is offline
tschmitt is starting off with a positive reputation.
Im in the same spot too, looking to order a radiator support next month and wanting to know which one will be the best for my 2wd 66'.
Old 01-09-2014, 07:01 PM
tetripp tetripp is offline
tetripp is starting off with a positive reputation.
Does the 65 support work on the 66? Does it have the inner fender supports? Also, do I need 65 or 66 mounting kit?
Old 01-19-2014, 05:53 PM
Quote:
Originally Posted by HotRod 66 F100 View Post
I am restoring a 66 2wd f100 stepside. I have looked high and low and this article from bluestang65 is the best and least confusing I have found. I am doing the exact same repair with a 61-64 radiator support from LMC.
Did this turn out ok? Did you use the mounting kit for the 61-64 or 66?
Old 01-19-2014, 06:06 PM
Quote:
Originally Posted by 66f100rat View Post
Just curious if bluestang has checked out the 65 to see if it was a better support? Looking to do the front end soon and would be thrilled if I could use the 65 support and only need to swap the radiator.
Thanks
Did this workout ok?
Thanx.....tetipp
Old 06-25-2014, 11:43 AM
Shadowrider123 Shadowrider123 is offline
Shadowrider123 is starting off with a positive reputation.
Wrong thread.
Veterans Day Sale at XDP!!! JeremyXDP Vendor Specials, Discounts, Product Announcements & Group Buys 0 11-08-2015 06:24 PM
Power Steering Bracket I.D.? Huntfamily53 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 9 04-25-2014 12:18 AM
Some ideas needed for new tail lights setup Bluey Zedoff 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 11-11-2013 04:04 AM
February All Topic SteveBricks S. California Chapter 495 03-01-2012 01:31 AM
Trying to Identify This Weird "Filler Neck" 68Ford4Life 1967 - 1972 F-100 & Larger F-Series Trucks 27 02-20-2012 10:47 PM
Tags
1961, 1966, 66, bluestang65blogspotcom, bronco, core, f100, ford, modify, radiator, support
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
