Roll Over Valve Clarification - 1950 F1
Hi Guys,
I've got a 1950 Ford F1 where we've done the 1970 Mustang tank replacement & we have it out back now in between the frames. One question has come up - If we use a Venting Gas Cap do we need the Rollover Vent Valve as well? Do they serve the same purpose? In a collision is it safe to have a Venting Gas cap back there? I'm curious what others have done. I also would like to know if I have to keep the vent hose up higher than the tank - Where do you run the thing? I've looked at numerous tank installs here and I'm not sure there is consensus on what to do.
Thx
Ben in Austin
Thx
Ben in Austin
On my stock tank, I have an unvented cap, so the roll over valve is the tank vent. Run a line from the valve to a place lower than the tank so if the truck flips the hose end is higher than the tank (belt and suspenders). Place a filter on the end, a gas filter will do, so you not sucking dirty air into the tank.
Hi Guys,
Thx
Ben in Austin
Thx
Ben in Austin
I'm not too confident in my picture posting abilities but I'll give it a shot.
Ben in Austin
Joes Restorations's Photos - "Under Construction" 1950 Ford F1 | Facebook
Ben in Austin
Ok - Let's see if the pictures will load now..
This is what our rear frame looked like when we took the bed off :
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=237345&width=1
This is where we are at now:
https://www.ford-trucks.com/user_gallery/sizeimage.php?&photoid=238402&width=1
[IMG]file:///C:/Users/Ben/AppData/Local/Temp/moz-screenshot.png[/IMG]
ben73058
03-27-2012 10:29 AM
ben73058
24
01-30-2012 10:07 AM
ben73058
04-18-2011 09:51 AM
ben73058
20
12-01-2010 10:54 AM
