2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
need help on liftgate panel removal
Old 01-17-2009, 07:53 PM
hipshooter's Avatar
hipshooter
hipshooter is offline
anyone tried removing the liftgate panel of a 2007 expedition? i'm trying to install a backup camera and need to remove the liftgate panel then run the wires to tap into the backup lights. i've been searching the forums but can't seem to find the right thread. would greatly appreciate any help. thanks.
Old 05-20-2010, 03:09 AM
st381's Avatar
st381
st381 is offline
Did you figure it out? I am about to do the same thing and any pointers you could give would be greatly appreciated.
Old 05-20-2010, 10:27 AM
berry1234's Avatar
berry1234
berry1234 is offline
PM me your email address and I will send you a pdf of the instructions.
Old 05-20-2010, 12:26 PM
st381's Avatar
st381
st381 is offline
Again, I don't know how to PM, . But I am willing to respond to one or learn if you explain how or point to the right sticky.
Thanks, st381
Old 05-20-2010, 12:31 PM
berry1234's Avatar
berry1234
Click my name and hit 'Send Private Message'.
Old 12-13-2010, 04:17 PM
astroman72's Avatar
astroman72
astroman72 is offline
Hi Berry,
I own a 2000 Ford Expedition and neither the liftgate nor liftgate glass open, with the key or the remote. The handle turns left and right (Glass/ Door) but nothing happens. My felling is that something either came loose or broke inside the liftgate.
With the third seat being so close to the liftgate I don't have much room to work with to try and remove the panel.
I need to get the panel off the liftgate in order to see what happened but don't know how and don't want to start forcing or prying without knowing what to do first.
Can you please help or point me in the right direction?
Thanks,
Astroman
Old 12-13-2010, 04:18 PM
berry1234's Avatar
berry1234
Sorry, not sure about the older models. I would post this in the 2006 and older forum.
Old 12-13-2010, 04:42 PM
astroman72's Avatar
astroman72
Berry, Thanks, will do.
Old 12-13-2010, 09:10 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
Old 12-15-2010, 01:04 PM
astroman72's Avatar
astroman72
TIKT,
Thanks for the images. Do you think I will be able to detach the fastners, specially the lower ones with the liftgate closed as it is now?
Rgds, Astroman
Old 12-15-2010, 03:40 PM
st381's Avatar
st381
st381 is offline
No, the lift gate will have to be open as the interior liner is sealed in the liftgate jamb. I successfuly removed the liftgate liner and reattached it. Just use firm and steady leverage to "pop" the retainers and all should be well. If your liftgate is stuck in the down position I recommend spending the money (I know its tight) and letting the dealer fiddle with it so you don't end up spending more to replace the interior liner or entire liftgate.
Old 12-15-2010, 03:42 PM
st381's Avatar
st381
st381 is offline
Another thought is you might try removing the interior handle to pull the gate down with which might give you enough room to see the locking mechanism and attempt to disengage it.
Old 12-15-2010, 04:57 PM
function12's Avatar
function12
function12 is offline
Originally Posted by astroman72
Hi Berry,
Thanks,
Astroman
Have you tried turning the handle while someone on the inside pushes? Just a thought.
Old 12-29-2010, 10:13 AM
astroman72's Avatar
astroman72
Hi fellas,
According to the pics TIKT posted, there should be two scrivets visible once I open the Glass door. Well, I managed to open the glass door by removing from inside the vehicle, the two screws that hold the handle. But sadly, I find that the lower panel completely covers the locking mechanism (it appears that the panel slides down over the lock and no scrivets are visible. Maybe the images are not for a 2000 Expedition.
I removed the windshield wiper and the rubber cover on the liftgate wiper motor shaft. I managed to stick a wire hanger through the hole where the wiper motor shaft sticks out of, and was able to release the lock of the glass door by pushing downwards and removed the glass door locking latch. As much as I tried through the glass door lock and the windshield wiper hole, I couldn't get to the side of the lock mechanism that actuates the lower part of the liftgate door lock to release it.
The worse part is that I can't remove the inside lower panel because as St381 indicates, the interior panel is sealed in the liftgate jamb.
Unless someone comes up with a better solution, I guess I'll have to take her into the dealer and hope they want to do the work as they do not accept any Ford for repairs that is more than 10 yrs. old.
Regards and Happy Holidays!!
Old 12-30-2010, 08:40 PM
TIKT B8's Avatar
TIKT B8
TIKT B8 is offline
No the images are for a 07+ Expy or Nav. Sorry for the confusion.
husker3in4
Escape & Escape Hybrid
02-06-2014 05:58 PM
Sweetpea02
05-07-2013 08:25 PM
BB Blue
Bronco II
06-27-2010 06:47 AM
st381
06-05-2010 09:11 PM
ExplorerSport97
07-21-2005 07:31 PM
Quick Reply: need help on liftgate panel removal
