I had a flat the other day, and my good jack was at the house. I had to use the factory one under the hood. In trying to get it our I broke some sort of white vacuume tube in that area. Does anyone know what it goes to or the part number for it. I am on vacation with my family and do not have access to it for pictures. I would have called it a wire, but it is some sort of vacuume tube, just not sure what it goes to???? Thanks in advance.
I think it's the one for that thing next to the fan motor. I can't remember what it was for though. fresh or recirc maybe? That stuff is hard to replace. And to find. I usually just get some rubber vac tubing and slip it on.
I also broke one and yes as RR said, or you can use the kind of tube for the boost gauge, and works fine.
BTW Ill later could put a pic if you want to. (its in another PC)
