Glow Shift Diesel 3 in 1 gauge, has anyone used them?
Looking to get the Glow Shift 3 in 1 gauge. Looks like a good setup without having the cab full of gauges. Did some searching on here but nothing comes up for this gauge. Just wondering if anyone has used them and how well it works. Looks like a good deal for the money, besides I am looking for EGT and Tranny temp which some of the digital gauges don't offer without spending big bucks.
If the combo gauge was avail. (or maybe it was and I was not aware) when I bought my gauges I would have got it, looks like a good idea. I have a single glowshift fuel psi and so far has be excellent.
thats cheeper then on ebay.
I will also add if you have a truck that has the boost gauge on the dash it is pretty accurate. so you may want to sub that gauge out for fuel pressure or something else.
I'm happy with my glow shift gauges. In a previous post someone commented that they didn't care for the glow shift gauges because the gauges couldn't be dimmed with the rest of the gauge cluster but this is not true... I have my gauges hooked to the dimer circuit and the gauge lights dim fine...
Before anyone buys glowshift products, do a quick google search for a coupon code to use at check out. I got one and saved 10 or 15 percent instantly. Cant remember which.
WFO440 (or anybody), did you ever try the GlowShift 3-in-1 Diesel Combo gauge? How do you like it? Also, anybody have a valid GlowShift coupon code? The "Save10Sept" is expired, not surprisingly.
I have installed a 3 in 1 Diesel EGT, Boost and temp gauge in my 2007 F250 6.0L. I'm not very happy with the readability of the gauge. The numbers on the analog dial light up but the indicator needle doesn't so it's very hard to tell what temperature you're at. The digital readouts are small and hard to read in daylight, even with the hood that comes with the gauge enclosure. Other than that, they seem to be pretty accurate.
I just bought my Glowshift Elite 10 Fuel Press a couple weeks ago, If i remember right ,,i used the code "winter11" and got 10% off..
Right before i went on their site to buy it , i googled Glowshift discount codes..That's how i found it.
Just got mine in the mail.I chose a 4 gauge A-pillar mount.I'll post back when their up and runn'in.Got Elite 10 EGT.Trans Temp,Fuel pressure,Wide Band A/F ratio.......
