Need HELP Please
Need HELP Please
I just replaced the EGR Cooler on my 2004 Ford F250 V8 6.0L Turbo Diesel, plugged everything back in the right spot, had it running for about 15 mins, then put it in reverse and stepped on the gas and nothing happened. The engine didn't even rev when I stepped on the gas.Tried it in Drive and same thing happened. It started to idle really rough and then it died. Tried to start it back up and now it doesn't start. Does anyone have any ideas? Thanks.
Suppose you didn't do something related to the oil cooler right... and there is no oil pressure (either low or high oil pressure), you would not be able to get it started.. or it would start and it would sputter and die as soon as the HPOP have no oil to pump.
Think about that.
Oh.. completely concur with 06silver.
If you have a failed EGR cooler, it is time to do both Oil cooler and EGR cooler, AND to add a coolant filter, and to do a complete flush with VC-9.
Think about that.
Casey_78
20
12-18-2008 10:15 PM
maevans
12-03-2008 09:46 PM
