OBDII port - Ford Truck Enthusiasts Forums
OBDII port
Old 12-26-2010, 09:08 PM
pnj442's Avatar
pnj442 pnj442 is offline
pnj442 is starting off with a positive reputation.
OBDII port
Probably a dumb question but can the OBDII port be split to accomodate additional gauges. The wife bought me one of those Garmin navigators and has the ability to Bluetooth data from the OBD port to the device but I don't want to remove the Edge Insight that is already plugged in. The Garmin has some neat features so I was wondering is there a pigtail-like device.
Old 12-26-2010, 09:09 PM
Hank85713 Hank85713 is offline
Hank85713 is gaining momentum as a positive member of FTE.
glad you asked as I was going to ask the same thing.
I would imagine you can make your own Y cord to do it with if you can find the compatible connectors.
Old 12-26-2010, 09:13 PM
pnj442's Avatar
Here it is. Reviews other places say that connectiing two devices to the same OBDII port may cause conflicts and either, both or none may work.
Amazon.com: Garmin ecoRoute HD Vehicle Diagnostics Communicator: Electronics
Old 12-26-2010, 09:14 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
***** Emeritus
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Old 12-26-2010, 09:16 PM
pnj442's Avatar
Yup. There it is. Gotta love Google. Sorry for not looking it up to begin with. Now back to your regularly scheduled Sunday Night
Old 12-29-2010, 10:39 AM
guygaro guygaro is offline
guygaro is starting off with a positive reputation.
Splitter cable Y
Here's a lower price one, $16.00
Obd2 Splitter cable
Google is great.
Guy
Old 12-29-2010, 10:55 AM
lenzhotrod lenzhotrod is offline
lenzhotrod is starting off with a positive reputation.
First there are no dumb questions, just dumb mistakes. Electronics can be strange at times when using a splitter device. Just because someone makes it does not mean that it will always work. Also on identical vehicles what works for one will not work for the other!!
Old 12-29-2010, 11:22 AM
gearloose1 gearloose1 is offline
gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.gearloose1 has a good reputation on FTE.
I need to check the documentation for the CAN bus.
But as a bus, normally it needs a bus master to be able to use two active devices on it at the same time.
Does it have it?
Old 12-29-2010, 02:06 PM
dchamberlain's Avatar
dchamberlain dchamberlain is online now
dchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputationdchamberlain has a superb reputation
More than just the CAN buss also. On the '04, there is the CAN, ISO, SCP and UBP busses. I don't know if all of those continued on through 05 and beyond, however. I believe the eventual goal of OBD-II was to be all CAN eventually.
Attached is a PDF with a description of the 4 busses and what they connect. This is for an 04, I can't vouch for any other years.
Old 12-29-2010, 06:19 PM
davidkstyler's Avatar
davidkstyler davidkstyler is offline
davidkstyler has a good reputation on FTE.davidkstyler has a good reputation on FTE.
...and this one is even cheaper with a couple of good reviews.
Amazon.com: Cable, J1962M to 2-J1962F, Splitter Cable, 1ft (145802): Automotive
Ford Navigation vs garmin rwinegar 2007 - 2014 Expedition & Navigator 6 04-11-2015 08:04 AM
OBDII port beemr 6.0L Power Stroke Diesel 3 03-27-2014 01:59 AM
Garmin ecoRoute - anybody using it? flixden 2009 - 2014 F150 8 08-06-2012 05:21 PM
Tapping into power at the OH console Lastwagen Audio & Video Systems, Navigation, Satellite Radio & Mobile Electronics 3 03-25-2012 04:36 PM
Garmins Eco Route HD capt caper 6.4L Power Stroke Diesel 2 07-09-2010 08:29 AM
Tags
2003, 2010, 60, ecoroute, f150, f250, ford, hd, ii, obd, obdii, port, powerstroke, trucks, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
