New 71 - Ford Truck Enthusiasts Forums
New 71
Old 12-26-2010, 06:24 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
New 71
Hello all, just stopping by to introduce myself and ask a few questions.
The door jam tag says birthday of 9/70, vin # matches title but title says 71, it that because it was built in the later part of the year correct?
And it has twin tanks, what is the switch position in regards to feeding off what tank?
IMO, outboard switch position is for main ='s rear and inboard is aux or side tank correct?
And where is the dang tank selector valve itself?
I go it as another project, and its a mess and needs some TLC, just going to make it reliable and continue to wheel it.
It has moved to to top of the project list, BTW. And I am trying to get smart as possible on these things thru the web so as not to bother anyone on here with a newb question.
Old 12-27-2010, 08:47 AM
gfw1985's Avatar
gfw1985 gfw1985 is offline
Cranky Old Guy
gfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to allgfw1985 is a name known to all
Gauge selector switch is on dash, tank selector is between your feet below the seat. Can't remember which way is which. Another good source for you is classicbroncos.com
Looks like it has seen some bogging. Enjoy, should make a fine trail rig.
Old 12-27-2010, 09:01 AM
77&79F250's Avatar
Used OEM parts guy
Ok so the switch that is on the far left side of the dash, just below the throttle ****, is just for the fuel gauge?
I thought the switch on the dash was to electrically switch between the tanks, or am I misunderstanding something here?
Old 12-27-2010, 09:13 AM
gfw1985's Avatar
Cranky Old Guy
Correct. Dash switch is gauge only, tank switch is manual. But after all these years and owners, you'll probably have to trace the fuel lines. I've owned four and worked on many more from 66 thru 77 and haven't seen an electrical tank switch stock, not saying you won't find one though. It would still be a solenoid style valve where the tank lines meet.
Old 12-27-2010, 10:06 AM
77&79F250's Avatar
Used OEM parts guy
Ok I got it, the gauge doesn't work any way. I think I'm going to drop the tanks and give them a good cleaning and see what is hooked up to what.
There is alot of PO mods done to it that I am still trying to figure it all out, thanks for the help, I'm sure I'll have more.
Old 12-27-2010, 10:24 AM
chrlsful's Avatar
chrlsful chrlsful is offline
chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.
...alot of PO mods...
...door jam tag says birthday of 9/70, vin # matches title but title says 71...
ditto in tryin to ID from one single tag. For some reason in the 90's these things became very popular to hack up or otherwise mod. U can never tell what's been done with one unless you've seen a lot of them NOT modded.
I run down each part number (had er since '83) than average the sum out ;- }
It took 3 - 4 to get mine back toward original. May B if it wuz a $10 or 20 thousand rig all would match. But none a dat would match ME!
I C U got may B 3 FS Bronks. Any have the sliding side windows in the back?
Old 12-27-2010, 10:27 AM
gfw1985's Avatar
Cranky Old Guy
Judging by your list of vehicles, you're no stranger to previous owner "modifications". Enjoy, they are fun trucks.
Old 12-27-2010, 11:08 AM
77&79F250's Avatar
Used OEM parts guy
Sorry Chad, 1 came with no top at all, 2nd with the rear windows blown out of it (was rear ended) and the 3 has regular just plain glass, no slider.
But I just seen on MO craigslist a top with sliders for $200?? I think. BTW all 3 FSB are for sale, ck out my FTE garage if interested.
I need to sale them to fund my latest project.......lol
gfw1985, I have got a few "modded" trucks, PO installed front blocks and stacked back ones......duuuuuhhh.
Old 12-27-2010, 11:15 AM
chrlsful's Avatar
got some eye candy 4 yer late X-Mass. Aint read how 2 post pic here yet. I can just attach to an e-mail if U wanna (see below n post 2 me or) send me yer email. Came from my 1st EB rally last summer.
Old 12-27-2010, 09:47 PM
77&79F250's Avatar
Used OEM parts guy
Well got the exhaust pipe ran from the headers to just pass the xfer case crossmenber area might hang some mufflers on there.
Enjoyed a 15 min drive around the property, still need to tune the carb, but it runs.
Looks like I have no actual switch to go from main to aux, also looks like they might be plummed together, I'll know when I drop the tanks.
Old 01-01-2011, 10:15 AM
77&79F250's Avatar
Used OEM parts guy
Side tank dropped, was full of gunk and not even hooked up to anything. The filler neck was not even connected to the tank anymore.
So its staying off, one less thing to drag on a rock, now to get to making my sliders to save those rocker panels.
Making a tread plate overlay, so I will end up having a small storage area under the pass seat.
Old 01-01-2011, 10:36 AM
gfw1985's Avatar
Cranky Old Guy
The nice thing about EB's is the fact you can "redesign" them to your personal use. What engine/tranny/gearing is in it?
Old 01-01-2011, 11:08 AM
77&79F250's Avatar
Used OEM parts guy
Was a 6 cyl with a 3 on the tree, clutch pedal is still there. The PO swapped in 289 C-4, not to sure on the axle gearing, I am still figuring it out as I go.
I know it now has a disk brake front end, and p/s (not a factory option for that year, correct ?) Trans and p/s coolers, alum rad w/elec fan and I believe a different rearend also 8.8 or 9" right?
Am going to do the tire-d/s rotation thing to get the gearing, but I know its LOW.
I am trying to get it to at least start/idle and shift in gear (cable just broke). One thing for sure I am having fun with it.
Old 01-01-2011, 11:38 AM
gfw1985's Avatar
Cranky Old Guy
Well, it has a T shift Dana 20 TC, low range is lower than the J shift. I would have to check my pic's a bit, but 71 would have had Dana 30 front axle, later years, Dana 44. Easy to check as it will have a castellated nut on top of the knuckle's(ball joint). PS and disc were available 76-77, but could have been added.
Old 01-01-2011, 12:41 PM
77&79F250's Avatar
Used OEM parts guy
Thanks for the info, I found some #'s on the xfer case going to run them and see what I can pull up.
Rear Gas tank not pumping & Gauge not reading for both tanks cajuntrentf100 1987 - 1996 F150 & Larger F-Series Trucks 5 08-15-2016 05:38 AM
91 F250 no fuel - help tylerz71 1987 - 1996 F150 & Larger F-Series Trucks 6 05-29-2016 06:39 PM
dual gas tanks coonhunter 1973 - 1979 F-100 & Larger F-Series Trucks 11 03-22-2016 02:00 PM
Transfering a title, do i need a notary Anthony Polsinelli 1973 - 1979 F-100 & Larger F-Series Trucks 12 01-18-2016 06:30 PM
1979 F250 Build maytea 1973 - 1979 F-100 & Larger F-Series Trucks 66 03-31-2015 06:40 PM
Tags
71, 71ford, 72, 77, broncofix, broncon, f100, fenders, ford, glass, idle, lexan, sale, truck, winshield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
