New 71 - Page 9 - Ford Truck Enthusiasts Forums
New 71
  #121
Old 05-27-2014, 01:39 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Yes grandkid safe, not my pant leg it belongs to a fellow FTE member.
The hillbilly bug is for fun for sure.
  #122
Old 05-31-2014, 11:07 PM
77&79F250's Avatar
Used OEM parts guy
Middle roll bar legs are now tied to the frame. Plan on the front legs of the roll cage and the home made rock sliders, and tie all that into together.
Something like the last 3 pics?
Also going to change the front bumper to match the rear.
  #123
Old 06-02-2014, 09:10 PM
chrlsful's Avatar
chrlsful chrlsful is offline
chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.chrlsful has a good reputation on FTE.
further safety on the '71
Thanks for passin on ur design ideas... wish more would incorporate
their r. bars to the frame! One guy had the sliders angle so's to slide offa
what ever they encountered (House-o'- Diesel's thread on here).
Solid ideas, U Go Rich!
  #124
Old 06-02-2014, 10:24 PM
77&79F250's Avatar
Used OEM parts guy
Yes I am still working the frame tie in... I am not done with it. I am going to cut the rockers and make the sliders tie in to the frame like the blue bronco set up, but trying to catch the front cage down pipes in the process.
I might just boat side it from the bottom of the rocker and run 1/8 sheets to the bottom of the frame. And use a old F250 trans cross member as a trans out put skid shield.
Also need to put a drag pan on the aft fuel tank, I ditched the aux under the dvrs seat.
  #125
Old 06-08-2014, 08:17 PM
77&79F250's Avatar
Used OEM parts guy
Tool boxes repaired from being made to fit around the old roll bar and back in. Ditched the rear bench and going with some Super Cab jump seats.
Here is what needs cut out of the dvrs side fenderwell tool box (for a full size truck) to make them fit.
And no tailgate of course, but great way to get some storage. I can fit a 5 gal military gas can and a spare set of complete front and rear d/s...and a ton of other stuff....
I was "test driving" the 2 small ammo boxes, they are not going to be used.
Got the old front bumper off and about ready with the square tubing that is going inside the frame to be welded to the new front bumper, it will look just like the rear one.
Yes the bumper/frame/body lines are off, it has had a hard life and been twisted a few times and more hard times are coming. It has a 1" spacer?? on the dvrs side and a worn out factory rubber one on the passenger side. I though about pulling the 1" spacer but the frame is tweaked already, so there is no real fixing it.
  #126
Old 06-13-2014, 11:39 PM
77&79F250's Avatar
Used OEM parts guy
Got the rear bumper set up with a double lock pin for the receiver winch plate and got the front bumper welded on. Will do the double pin trick on it too, also made some reinforcement passes on the front and rear "D" rings.
Kicked around a "stinger" idea and decided to kick it into the corner of the shop for now, untill I can get some other angles bent up. Also had to relocate the spare tire mount a little higher up, it hit the top of the winch being so low.
Yes I have to clean up the bottom of the winch plate, it had a alternate trailer mount leg that will be a snag hazard now. So now I have to redo the trailer winch mount set up.
Just have to wire the Bronco with front and rear QD's for the power.
  #127
Old 06-14-2014, 07:12 AM
chrlsful's Avatar
continued developments
Movin fast now, bet ur a fast tracker when not playin too (@ work).
Beefin up those D rings looks like for pullin others out, big red looks
'fully capable' now!
I thought those full sz tool boxes reduced departure angel but the pic show that's not so, thanks.
Now that I know the extra few inches can still work I'd like to look-in on that idea for mine (log chain, chain saw, etc)...
  #128
Old 06-14-2014, 09:11 PM
77&79F250's Avatar
Used OEM parts guy
They are standard full size pick up steel fenderwell tool boxes. I got mine off the Craigslist for 50 bucks for both (sweet deal) IMO, compared to the below prices. They are 48" x 8", 38 " might work with a tailgate? Here they are made by Delta.http://www.sears.com/delta-850000d-4...&blockType=G23
Wheel Well Tool Boxes
Wheel Well Tool Boxes - Truck Customizers
Wheel Well Truck Boxes | Truck Boxes: Crossbed Truck Boxes, Underbody Truck Boxes + More | Truck Boxes | Northern Tool + Equipment
Test driving it around the back 40 today I managed to plug the front receiver full of dirt. I am coming up with a steel plug or mini bumper skid plate to keep it ready to take the winch.
If that winch/receiver plate was not so heavy (est 100+ lbs) I would on mounted a holder/receiver to the middle of the spare tire mount (old axle face) to carry it out of harms way.
But that would be way to high to get it up in there by myself, so it's going to be hanging off one end or the other.
  #129
Old 09-04-2014, 01:14 PM
77&79F250's Avatar
Used OEM parts guy
Here is a couple of storage ideas...I know the 2nd idea was taken from a EB originally. lol
  #130
Old 02-01-2015, 11:04 AM
77&79F250's Avatar
Used OEM parts guy
  #131
Old 02-13-2015, 11:30 AM
chrlsful's Avatar
Quote:
I like what u have in the "bronk storage" jpeg. I wuz thinkin of usin the wagon cap w/o the windows and placing doors that raise up (like on some p/u truck caps) with a storage box inside them where the windows were originally. Still have most the bed to store things...
  #132
Old 02-14-2015, 11:04 PM
77&79F250's Avatar
Used OEM parts guy
Cool idea on the cap storage, but you loose it when you go topless.
Seen this? http://www.dufftuff.com/Upper_Quarte...nco_p/7150.htm
NO ONE with any axle advice or opinions?
  #133
Old 02-15-2015, 11:55 AM
Nothing Special's Avatar
Nothing Special Nothing Special is offline
Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.Nothing Special has a great reputation on FTE.
Sorry, no. I put higher strength axle shafts in my Bronco's front axle, but it was a while ago and I don't remember specifically what they were.
My opinion is that most of what's out there is pretty good. Some might be a little stronger, or a little cheaper than others. But I don't think you can go far wrong with much of anything.
  #134
Old 02-15-2015, 12:07 PM
77&79F250's Avatar
Used OEM parts guy
Since I am getting it as a 3nd or 4th hand "project" I am going off what I was told by the last to owners and by what I have figured out.
Best I can figure out it has a D44 with dish brakes, TRE (tie rod flip?) steering mod, front locker along with the F150 steering box mod and sag p/s pump.
I just had the passenger side spit the u joint cups out when doing a little wheeling. So I am going to pull the axles count the splines and see what I need to get.
Sound like a good plan? Thanks for the advice.
  #135
Old 02-15-2015, 01:37 PM
Sounds like a plan to me. Fortunately my Bronco was pretty much stock when I got it (cut fenders, 33" tires, a 6" lift, converted to power steering and floor shift about the only mods). So I didn't have any trouble getting axle shafts that dropped right in. I don't know how many variables there are, but I wouldn't think you'd have too much trouble getting axle shafts that'll fit.
By the way, my Bronco still has an open front diff. As long as it stays that way I don't think there was any need for me to upgrade the axle shafts. You already broke something so upgrading seems like it makes sense for you. But for anyone else following along, unless you've had trouble, are running a front locker, or have a really fat right foot, you can probably save yourself some coin by sticking with the stock shafts.
dual gas tanks coonhunter 1973 - 1979 F-100 & Larger F-Series Trucks 11 03-22-2016 01:00 PM
Transfering a title, do i need a notary Anthony Polsinelli 1973 - 1979 F-100 & Larger F-Series Trucks 12 01-18-2016 05:30 PM
1986 F-150 Lariat ? kc5wxc 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 08-23-2012 08:16 AM
89 F150 4x4 Dual Fuel Tank Switch predaina 1987 - 1996 F150 & Larger F-Series Trucks 29 03-29-2011 07:07 PM
Single to Dual Gas Tank Conversion? Aaron-71 1973 - 1979 F-100 & Larger F-Series Trucks 8 07-23-2010 03:11 PM
Tags
71, 71ford, 72, 77, broncofix, broncon, f100, fenders, ford, glass, idle, lexan, sale, truck, winshield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
