New 71
#76
Glad things aren't worse, U & family are OK. Not as bad as it wuz down the road abit. Fortunately U aren't in Tornado Alley (aint dat on the TX / LA border?). My 'ex's" "ex" is from the rez in OK & they got alot of twisters...
Stay close to the radio May thru November, those Earth Changes (what we called them when predicting this stuff in the '60s) have increased intensity, duration and frequency over the last several decades...
Let us know if you need anything bro.
#77
Ok yes it could of been alot worse, like cross the border in Moore Oklahoma......house and family are ok, truck can be fixed.
I am right on the southern border of the tornado alley....weather radio and storm shelter are on and ready.
On a good note, I got a front and rear d/s that are fresh rebuilt. CVC joints and all off the craigslist for $150, yahoo for trail spares.
#79
A 3/4 in the ground 18,000 lb 6000 PSI concrete storm shelter similar to this....
Missouri Storm Shelters | Springfield, Missouri - Conventional Shelters
#80
#81
#82
I'd love to see the brackets that install on the frame.
How will you cut thru the floor boards (torch? 4 1/2 inch wheel? sawzall? die grinder?) and will there be "grommets" when passing thru there - so the uprights of the RBs pass thru an air/water barrier? May B I'm thinkin too fancy for not street registered/off rd/a different state's requirements...
Thanks
("a pic's worth....." [hint, hint] we just luv pic!!!)
Thanks
#83
The floor pans and under seat decking is 3/16th tread plate overlay now. So I will either weld to it or grade 8 bolt the RB mount plates to the bottom frame support bar plates.
I am using the frame mount tie in brackets from the donor Bronco, they were welded to the frame but bolted to the roll bar plates. I am frame welding them again and might tie into the rock sliders also??
The aft kicker bars will be welded to the double tube back bumper.
If that all makes since......and yes I will pic document it all. Air and water tight barrier, not to worry, I am not cutting any holes.
#84
#87
#88
#89
#90
I scored a complete top with almost zero rust, a littel on the front under edge in a few spots. All the OEM side glass is there with the chrome trip and the chrome trim around the whole top.
Back glass is awesome and so is the back window mechanism.
A set of doors with only one inner door panel missing, all the glass and wings and upper window frame is there and its chrome to boot. Only light surface rust on the bottom edge NO dents.
A 1968 hood without a dent or a bit of rust. A windshield and frame, a complete (instruments all OEM switches/*****) dash with the ignition keys that match the door locks.
A set of Tan OEM front buckets.
Might even get the title (to the glove box warranty/vin plate, if he can find it.
Pic tomorrow.
Pic tomorrow.
