New 71
#181
Nope, it's cutting the bottom off the rocker (shortening the height, not the length) and then replacing it with some tubing. Gives more clearance for rocks, bets rid of a (usually) rusty piece of sheet metal and replaces it with something that can take it's knocks as a rock slider.
Thanks 4 the lesson Bob!
#182
#183
"Pic worth 1,000 wrds."
glad U cont 2 tie into the frame/cage. Many do not.
Several have 'canted' the slider - lower on the frame inner side / higher on the door outer side - claiming it's a good angle for staying off the rock (true meaning of 'slider') once you've slo motion empaled urself on them…
Continues to B a well thought out, quality project! Thank you for allowing us to follow along!
In Community,
Bro Chad
In Community,
Bro Chad
#184
#186
New bumpers front and rear from a while back. I think 2x4?
I welded long tubes on both bumper backside and then these brackets were put into the inside the frame rails frame and bolted and welded all the way around.
Still a project. With the back half of the roll cage, the inner fenderwell tool boxes fit great and so does the 35" spare.
#187
newer frnt bumper - what diameter?
I saw a new front tube bumper. It has just bout the right diameter.
The old rear bumper looks like it's still on but of less interest in my inquiry about the tube diameter up front…
The '77 I cut up (10 yrs. ago?) to update my '70 had a huge (4 inch?) diameter tube. I created a hoist from it for the logs when skidin them up to the neighbor's. I held up some 1 inch tubes and they were too small. I'm thinking 1.5 - 2.5 inch will make a nice frnt bumper (has to avoid a sno plow, a winch and eventual 10 inch auger). Just not sure the size - yours looks like a size I could go out and get a of scrap to try.
#188
Chad clean out your PM inbox....
Old front tube bumper when I 1st got it. 2 main cross bars 3 1/2" OD each, top loop 3".
Old rear tube cross bars 3" OD each.
New front and rear bumpers are the same, 2"OD X 4" OD Rectangle tubing. Tapered off to 3 1/8" on the ends.
They came on the 79 Bronco tough truck and I modded them (cut the ends off) to fit width wise when I did the new cage work.
I left the ends open, so I can get my highlift jack tongue tip in there.
#189
Mini flex test with a rock in the field and a small creek crossing. Yes I am going to have to trim the front inner fenderwell for sure.
And this was a mild flex test, I am also sure some of the outer fender will have to come off in order to run these tires and get the most out of the flex.
#190
#191
#192
#194
#195
top pic # 182
sorry, 3 different vehicles:
* shiny red W/hard, home fabed flairs ( a below shot of rocker @ 1 point )
* red (w/ orig. white race stripe circa '76)
* ur own.
Bumper Q is about (someone else's)1 seen in several shots, 1 of which is @ top of #182.
All set, tho - no response needed.
Thanks ~
* ur own.
Thanks ~
