In looking at this wiki photo, it has the 6 lug pattern with 6 handhole wheels. These are different than the other UPS vans with the 8 lug, or 6 lug with the more solid face. So my question is, what make is this one pictured?
The old ford chassis were used on the p600 same brake and clutch pedals as the 53-56 ford trucks. The six lug 5 hole wheels were standard for the p600,p800,p1000 ... the standard tire was the 9r22.5
P500 = P Series Parcel Delivery (no such thing as a P600) chassis used 1953/75, replaced by the E350 Cut-Away chassis in 1976.
Ken - The other thing that limits you to the wheels I've previously recommended is the stud/nut design and wheel mounting design. Your truck has 5/8" x 18 tpi studs/nuts while the bigger trucks used 3/4" x 16 tpi studs/nuts. Also, your truck used what's called a "coined in/out" wheel mounting that uses "90° conical faced nuts". The big trucks with stud piloted mounts used ball seat nuts. Stu
