Spark Plug Wire Crossfire? - Ford Truck Enthusiasts Forums
Old 12-26-2010, 01:57 AM
jv2290's Avatar
jv2290 jv2290 is offline
jv2290 is starting off with a positive reputation.
I was just introduced to the Crossfire thing in another post I seen. I keep posting about a cold start issue but when it warms up it's fine. (I got the 5.0 V8 in a 92 F250 E4OD trans) It actually starts like it's missing a plug or something but it's tuned up completely with new wires, plugs, cap, rotor and coil. Now my question is this.... Even though I have BRAND NEW NAPA Spark Plug Wires could they still crossfire? I don't see any sparks when I open the hood in a pitch black area. Could the be crossfiring under the cap? If you wanna know all I've done and replaced you'll see it all on my previous post. But anyway I can guarantee My wires aren't routed right. I don't even think my separators exist haha! But if it is crossfire I don't know why it runs fine when warm. Thanks in advance (:
Old 12-26-2010, 10:25 AM
Eddiec1564 Eddiec1564 is offline
Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.Eddiec1564 has a very good reputation on FTE.
I have the same problem with my 89 F250 302/aod under load it misses, drove me nuts trying to figure it out, finaly I found this:
Took care of the problem!
Old 12-26-2010, 10:38 AM
jjsfrd's Avatar
jjsfrd jjsfrd is offline
jjsfrd is starting off with a positive reputation.
Does anyone have the diagram for a '97 7.5l? I haven't seen it.
J
Old 12-26-2010, 10:53 AM
timbersteel's Avatar
timbersteel timbersteel is offline
timbersteel has a good reputation on FTE.timbersteel has a good reputation on FTE.
this link may help if your firing order is different than one pictured above.
1983 Ford Bronco TSBs & FSAs (Recalls) for '83-96 Broncos & F150s picture | SuperMotors.net
Hope this helps everyone!
Old 12-26-2010, 11:55 AM
jjsfrd's Avatar
I need the wire routing diagram for the '97 7.5. I'll do a search, but, while we're here, I also need it for a '78 6.6.
J
Old 12-26-2010, 12:24 PM
Sorry J, didn't mean to sidetrack the Post. I posted the link for JV2290. I'll look around for the wiring diagram for the 78, 6.6
Old 12-26-2010, 01:43 PM
jjsfrd's Avatar
No apology needed, I appreciate the help.
J
Old 12-26-2010, 02:27 PM
jv2290's Avatar
Unfortunately that wasn't my issue. I routed them correctly but It still runs bad. Thanks for the info anyway! I still learened something haha
Old 12-28-2010, 09:18 AM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is online now
EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.EPNCSU2006 has a very good reputation on FTE.
It's an inductive crossfire between 7 and 8 usually. Inductive means the current from one wire induces a voltage/current in the adjacent wire, so you won't see any arcs between the two wires.
Old 01-22-2011, 01:39 PM
Encho's Avatar
Encho Encho is offline
The Southernmost Mod
Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.Encho has a spectacular reputation.
Apparently the firing order in that sticker (Eddiec's) is only true for 5.0 engines built from 1994 on. The firing order for older engines, like mine, is 1-5-4-2-6-3-7-8.
Spark plugs lighting up Adamazar 1987 - 1996 F150 & Larger F-Series Trucks 45 04-01-2015 02:05 PM
Truck sputtering/bogging under load, I am stumped bcboy4ca 1987 - 1996 F150 & Larger F-Series Trucks 5 02-11-2014 03:03 PM
97 4.6L codes 302 and 306 intermittent problem ChargerFan 1997 - 2003 F150 11 01-28-2013 01:29 PM
Plug Wires and Crossfire SoCar72 1987 - 1996 F150 & Larger F-Series Trucks 10 07-25-2011 09:41 PM
Help diagnose '95 302 low compression / coolant (?) cylinder #5 geoaigel Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 6 06-11-2010 12:23 PM
Tags
1996, 302, 75l, bronco, cross, crossfire, fire, ford, inductive, plug, spark, sparkplug, v8, wire, wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
