Cooling System Capacity
Old 12-25-2010, 02:38 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat
Big-Red-Lariat is offline
misplaced my manual, would anyone know the cooling system capacity for a 2006 5.4L and how many jugs of coolant I need to buy?
The aftermarket places have a plain old green coolant flush parts & labour included for about $100.00 and to buy the yellow MOTORCRAFT stuff in Canada is $25 a jug just for the coolant. Should I use the MOTORCRAFT or aftermarket green?
Old 12-25-2010, 03:06 PM
shorebird's Avatar
shorebird
shorebird is offline
The '06 5.4L takes 20.9 quarts of the Motorcraft Premium Gold engine coolant.
Page 312 of the manual
https://www.fleet.ford.com/maintenan...ls/default.asp
Old 12-25-2010, 03:08 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Okay well its a big NO on the green!!! The correct coolant for your truck can also be bought as Zerex in the gold bottle and is only about 12.00 each at a parts store. Are you just going to drain the radiator and refill? Or do a complete system flush? You will need 2.5 gallons for a radiator drain and about 4 gallons for a flush.
Old 12-26-2010, 07:29 AM
Big-Red-Lariat
thanks for the comments---so why do these aftermarket guys purport that their green coolant is good for anything? The sob told me that FORD just dyes theirs yellow & its all the same stuff.
Old 12-26-2010, 12:33 PM
ford390gashog
Oh wow!!!! He is remedial for sure!! The color really means nothing but it can help a little. The ford yellow spec coolant is a HOAT "Hybrid Organic Acid Technology" coolant does not have any carboxylate salts in it which will ruin seals and metals. This is well known in the Dexcool coolant as that coolant is junk and ruins more things then it helps. The coolants they sell at the parts houses that say "for any color" antifreeze is simply not true. All that stuff is super high silicate coolant and will lead to drop out of the additives. Prestone comes to mind when I think of this, when used with Dexcool it creates a Jello like mess in the radiator and when combined with any HOAT it spikes the PH through the roof!!! So just use the correct stuff
Rafaello
03-08-2017 11:50 PM
Wilde Ford
03-13-2016 10:40 PM
Texas Outlaw
17
07-15-2012 08:09 PM
therifleman556
07-23-2009 09:08 AM
chipper
06-08-2004 01:38 PM
Quick Reply: Cooling System Capacity
