Cooling System Capacity - Ford Truck Enthusiasts Forums
Old 12-25-2010, 03:38 PM
Big-Red-Lariat's Avatar
Big-Red-Lariat Big-Red-Lariat is offline
Big-Red-Lariat is starting off with a positive reputation.
misplaced my manual, would anyone know the cooling system capacity for a 2006 5.4L and how many jugs of coolant I need to buy?
The aftermarket places have a plain old green coolant flush parts & labour included for about $100.00 and to buy the yellow MOTORCRAFT stuff in Canada is $25 a jug just for the coolant. Should I use the MOTORCRAFT or aftermarket green?
Old 12-25-2010, 04:06 PM
shorebird's Avatar
shorebird shorebird is offline
shorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputationshorebird has a superb reputation
The '06 5.4L takes 20.9 quarts of the Motorcraft Premium Gold engine coolant.
Page 312 of the manual
https://www.fleet.ford.com/maintenan...ls/default.asp
Old 12-25-2010, 04:08 PM
ford390gashog's Avatar
ford390gashog ford390gashog is online now
ford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to allford390gashog is a name known to all
Okay well its a big NO on the green!!! The correct coolant for your truck can also be bought as Zerex in the gold bottle and is only about 12.00 each at a parts store. Are you just going to drain the radiator and refill? Or do a complete system flush? You will need 2.5 gallons for a radiator drain and about 4 gallons for a flush.
Old 12-26-2010, 08:29 AM
thanks for the comments---so why do these aftermarket guys purport that their green coolant is good for anything? The sob told me that FORD just dyes theirs yellow & its all the same stuff.
Old 12-26-2010, 01:33 PM
Quote:
Oh wow!!!! He is remedial for sure!! The color really means nothing but it can help a little. The ford yellow spec coolant is a HOAT "Hybrid Organic Acid Technology" coolant does not have any carboxylate salts in it which will ruin seals and metals. This is well known in the Dexcool coolant as that coolant is junk and ruins more things then it helps. The coolants they sell at the parts houses that say "for any color" antifreeze is simply not true. All that stuff is super high silicate coolant and will lead to drop out of the additives. Prestone comes to mind when I think of this, when used with Dexcool it creates a Jello like mess in the radiator and when combined with any HOAT it spikes the PH through the roof!!! So just use the correct stuff
E-350 Mallard Sprinter motorhome temp? cbakker 1968-2013 Full Size Vans 1 07-16-2015 05:39 PM
coolant concerns Haywire-Powerstroke 1994.5 - 1997 7.3L Power Stroke Diesel 10 06-04-2015 01:50 PM
How much coolant does the 7.3 system hold? Texas Outlaw 1999 - 2003 7.3L Power Stroke Diesel 17 07-15-2012 09:09 PM
Coolant Capacity Pest007 1994.5 - 1997 7.3L Power Stroke Diesel 1 08-12-2009 02:20 PM
Motorcraft Gold coolant??? therifleman556 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 07-23-2009 10:08 AM
Tags
01, 05, 2003, 2004, 54, 73, antifreeze, capacity, coolant, cooling, f150, f250, ford, powerstroke, system
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
