air bag code 47
I'm assuming you're getting the code 47 from the air bag lamp flashing. 4 flashes, then a pause, then 7 flashes, then a longer pause, then repeats.
Code 47 is Passenger Pretensioner Circuit Resistance High. This could be a bad pretensioner, or a something as simple as a connector under the passenger seat disconnected.
Be very careful messing with Air Bag and Pretensioner wiring. It doesn't take much static electricity to set one off.
Airbag code 4-7
I have the same 4-7 or 7-4 code blinking then the light goes solid on. Does anyone have a wiring diagram of the passenger side seat? I like to know what I'm working on before I start poking around.
The truck was in a very minor bumper bender, strickly cosmetic on the bumper. The Lincoln dealer installed a new bumper but that was about a year ago. The light is a recent addition.
The seatbelt is located inside the seat as this is a supercab truck. I only noticed two wires going into the bottom of the seat, I guessed they were for the seat belt fastened light. I would guess that signal is in series with a weight on seat switch so the light, buzzer don't go on with an empty seat. Let me know if there may be another wire harness to the seat that I didn't see during my quick inspection. Thank you all for the assistance.
jlewis44047
03-08-2012 11:25 PM
